Light Dimmer Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 11:27 PM   #1
DXL
Lightbulb
light dimmer problem
i have noticed that at the same time 2 separate sets of my dimmer switch operated ceiling recessed lights (2 bulbs to each switch) stopped working. light bulbs are ok and fuses for the house are ok too. LEDs on both switches
went dead . Are these switches equipped with some sort of internal fuses.
There may have been weather-related momentary power outages when this occured.Any thoughts? thanx
DXL is offline   Reply With Quote
Old 03-30-2008, 11:15 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I would use a voltmeter to trouble shoot this. Without a voltmeter, I would pull one of the dimmers out (turn the power off). I would then connect the source and switched wires together, temporarily bypassing the dimmer, to see if the lights came on. Do the connections with the power off, then turn it on to check the lights, then turn it back off to put things back to normal.
Do not mess with electricity if you doubt your ability. Calling an electrician never killed or hurt anyone.
jrclen is offline   Reply With Quote
Old 03-30-2008, 04:28 PM   #3
Union Electrician
goose134's Avatar
Sometimes the switches have a system switch. Lutron Maestro is a good example. Check to see if there is a very tiny switch on the front of your dimmer. Either at the bottom of the decora style rockers or sometimes at the bottom of the slide bar.
This actually kills the dimmer switch. You should never work on a dimmer while it's hot. This switch will NOT turn the circuit off. Just the device.
goose134 is offline   Reply With Quote
Old 03-30-2008, 07:57 PM   #4
DXL
Thank you!
DXL
Old 03-30-2008, 07:58 PM   #5
DXL
Thanks!
DXL
Old 03-30-2008, 09:03 PM   #6
Union Electrician
goose134's Avatar
was that it? You're welcome!
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
Christmas light problem bucksone Electrical 1 12-07-2007 05:45 AM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 08:20 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 09:16 PM
