Light Bulbs Going Out - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 08:30 PM   #1
Light bulbs going out
I have 3 lights outside that i am replacing the bulbs maybe every other week. It's not the same light each time, it a different one abd it is getting expensive. Any idea what this could be? The tag on the fixture says no more than 100W, so I have gone with 100W. Would a lower wattage bulb solve this problem or would a short in the wires somewhere cause this?
Thanks,
Tim
timchi29 is offline   Reply With Quote
Old 01-17-2009, 08:41 PM   #2
Thanks,
Tim
Might be a loose neutral...do this lights dim or get brighter when loads are started?
rgsgww is offline   Reply With Quote
Old 01-17-2009, 09:03 PM   #3
No. I just get home, flip the switch and notice a light is out? Would the loose netral be at the panel or at any of the lights since they are on the same circuit?
Old 01-17-2009, 09:05 PM   #4
dSilanskas's Avatar
Vibration of the doors being shut?
dSilanskas is offline   Reply With Quote
Old 01-17-2009, 09:36 PM   #5
Rewards Points: 894
Extremely cold weather?
An incandescent bulb's filament starts out with a very low resistance, which will drop as ambient temperature drops.
In colder weather, the inrush current on a 100W lamp may increase enough to cause premature burn-out.
Try replacing the bulbs with the new CCFL screw-in bulbs. These will take some time to come on in the cold weather, but I think they will last a lot longer.
Another factor could be the brand of light bulb. There is a lot of crap coming across the ocean from... you know where, and I am sure they don't make them as good as the old GE or Westinghouse (although, to be honest, I'm not sure even those guys don't have their bulbs made in the same place as the cheap ones)
Ultrarunner2017 is offline   Reply With Quote
Old 01-17-2009, 09:38 PM   #6
Electrician
Dont buy lamps at the dollar store.
chris75 is offline   Reply With Quote
Old 01-17-2009, 11:23 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there is a difference is quality.
one person mentioned "vibration". That is a big cause in some situations. A quality lamp will help. A rough service lamp will help even more.
Old 01-18-2009, 08:02 AM   #8
Thanks. I use Westinghouse 100W bulbs. I just looked on the box and these are a "Value" bulb. They make a "Preferred" and a "Superior". They are $3.50 each and and I have tried an ACE Hardware bulb ($7) each, but will give a name brand higher end bulb a shot.
Old 01-18-2009, 08:06 AM   #9
Electrician
The other thing, are these fixtures on all night and day? you would be surprised how fast they seem to be going because someone forgets to turn them off.
Old 01-18-2009, 08:33 AM   #10
dSilanskas's Avatar
See if your bulb says 120 or 130 volts if you only have the 120 volt bulb you should try the 130 volt bulb.
Old 01-18-2009, 09:04 AM   #11
Rewards Points: 1,192
Go with a compact fluorescent lamp.
bobelectric is offline   Reply With Quote
Old 01-18-2009, 09:15 AM   #12
Eibwen
Three lights doing that is kinda odd.. But if the bulbs are all the same quality it may be the culprit.
As previously stated I would switch at least one bulb up to a quality long life or rough service bulb. Rough service has a shorter life but a heavier filament.
Swapping out the switch for a dimmer may help. It allows the light to come on slower rather than a "full on"
I have two outside photo lights that come on dim before going to bright and the bulbs last several years easily.
Sammy is offline   Reply With Quote
Old 01-18-2009, 10:21 AM   #13
the problem with the CFL, is the light bulbs go in black lantern style fixture, so the bulb needs to be a candle looking style. Do they make those in CFL's?
What would 120v vs 130v accomplish? Don't know much about that so just curious.
Old 01-29-2009, 04:14 PM   #14
I solve dthe problem. I went to Lowe's and they told me to flip the breaker and pull up the tab/spring that the bulb screws into. Did that abd it works like a charm
Old 01-29-2009, 05:20 PM   #15
A loose connection causing more heat than a tungsten filament? Not very plausible.
Maybe the on/off intermittent contact, temp. cycling the filament.
Wait and see if the fix continues to work.
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 07:16 AM
losse light bulbs and dim slow ceiling fan vmnorton Electrical 2 05-04-2008 06:41 PM
clear light bulbs versus white ugabulldog Electrical 5 04-19-2008 10:42 AM
