Old 03-18-2009, 10:12 PM   #1
Light bulbs burning out
Again I was over helping a friend with some light fixtures. Their light above the sink says it is rated at 120v 75w. The bulbs they are using are a 65w, yet they are burning out within a week.
Are they maybe a bad batch of bulbs, can't think of anything else since the wattage is lower then the max for the fixture.
Michblaze02 is offline   Reply With Quote
Old 03-18-2009, 10:17 PM   #2
more of a voltage thing...get 130 volt bulbs they have sttronger filament...you need to check the voltage...but, if i had to guess you have a bad batch of bulbs
NolaTigaBait is offline   Reply With Quote
Old 03-18-2009, 10:29 PM   #3
It was sitting at 122v consistently. So same wattage bulbs with a higher voltage rating . Could anything else cause bulbs to blow so quick.
Old 03-18-2009, 10:41 PM   #4
i'd try a different brand of bulb
Old 03-18-2009, 10:46 PM   #5
I will let them know. The white plastic around where the bulb goes in was a bit discolored as well. Signs of it being rather hot, would a higher voltage bulb with lower wattage help with lowering the heat output from the light.
Old 03-18-2009, 11:02 PM   #6
It was a dark and stormy
Yoyizit's Avatar
Vibration could shorten lamp life, as could a loose connection.
That is a very short lifetime. 122 volts into a 120v bulb should give you 100[(120/122)^14] = ~80% of rated lifetime and 44% for a 115v bulb.
Old 03-18-2009, 11:04 PM   #7
yeah,do you live under an interstate?
Old 03-18-2009, 11:22 PM   #8
One time my wife brought home a quanity of light bulbs that were on sale - cheap. They did not last long at all - seems I spent the next year or two doing nothing but changing light bulbs until I used them all up.
Old 03-18-2009, 11:31 PM   #9
Yoyizit's Avatar
Or have a honeymoon couple upstairs?
Old 03-19-2009, 01:41 AM   #10
My License Ain't 4 Sale..
If the heat can't escape effectively, lamp life can be reduced substantially. Vibration can also be a problem. Voltage too, of course.
Old 03-19-2009, 06:19 AM   #11
It is definitely getting warm under the glass housing. I guess a lower wattage bulb would help somewhat with that. No vibration though, they live on a quiet dead end road, and ranch style house.
Old 03-19-2009, 12:39 PM   #12
Yoyizit's Avatar
Vibration as in people stomping around upstairs while the light is on, or doors slamming close by while the light is on.
Old 03-19-2009, 01:18 PM   #13
\hahah...nice one
Lamp outside front door burning out bulbs Vertical Electrical 12 08-21-2008 09:35 AM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 08:16 AM
losse light bulbs and dim slow ceiling fan vmnorton Electrical 2 05-04-2008 07:41 PM
clear light bulbs versus white ugabulldog Electrical 5 04-19-2008 11:42 AM
