-   -   Light bulbs burning out (http://www.diychatroom.com/f18/light-bulbs-burning-out-40644/)
Michblaze02 03-18-2009 09:12 PM
Again I was over helping a friend with some light fixtures. Their light above the sink says it is rated at 120v 75w. The bulbs they are using are a 65w, yet they are burning out within a week.
Are they maybe a bad batch of bulbs, can't think of anything else since the wattage is lower then the max for the fixture.
NolaTigaBait 03-18-2009 09:17 PM
more of a voltage thing...get 130 volt bulbs they have sttronger filament...you need to check the voltage...but, if i had to guess you have a bad batch of bulbs
Michblaze02 03-18-2009 09:29 PM
It was sitting at 122v consistently. So same wattage bulbs with a higher voltage rating :thumbsup:. Could anything else cause bulbs to blow so quick.
NolaTigaBait 03-18-2009 09:41 PM
i'd try a different brand of bulb
Michblaze02 03-18-2009 09:46 PM
I will let them know. The white plastic around where the bulb goes in was a bit discolored as well. Signs of it being rather hot, would a higher voltage bulb with lower wattage help with lowering the heat output from the light.
Yoyizit 03-18-2009 10:02 PM
Vibration could shorten lamp life, as could a loose connection.
That is a very short lifetime. 122 volts into a 120v bulb should give you 100[(120/122)^14] = ~80% of rated lifetime and 44% for a 115v bulb.
NolaTigaBait 03-18-2009 10:04 PM
yeah,do you live under an interstate?
vsheetz 03-18-2009 10:22 PM
cheap bulbs
One time my wife brought home a quanity of light bulbs that were on sale - cheap. They did not last long at all - seems I spent the next year or two doing nothing but changing light bulbs until I used them all up. :eek:
Yoyizit 03-18-2009 10:31 PM
Or have a honeymoon couple upstairs?
InPhase277 03-19-2009 12:41 AM
If the heat can't escape effectively, lamp life can be reduced substantially. Vibration can also be a problem. Voltage too, of course.
Michblaze02 03-19-2009 05:19 AM
It is definitely getting warm under the glass housing. I guess a lower wattage bulb would help somewhat with that. No vibration though, they live on a quiet dead end road, and ranch style house.
Yoyizit 03-19-2009 11:39 AM
Vibration as in people stomping around upstairs while the light is on, or doors slamming close by while the light is on.
NolaTigaBait 03-19-2009 12:18 PM
\hahah...nice one:laughing:
