Light Bulb Exploded - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 09:39 AM   #1
Rewards Points: 154
Light Bulb exploded
MY wife was dusting our light fixture, and must have done something to it, fractured the base in some way, because when she turned it on one bulb exploded, the base is still in the fixture, but I don't see anything I can grab on to in order to unscrew the damaged bulb. I can't replace it while the base is still broken off in there, I know I should turn off power, from there any ideas how I can remove base? Thanks,
turbomangt is offline   Reply With Quote
Old 10-29-2010, 09:45 AM   #2
firehawkmph's Avatar
Rewards Points: 1,868
Turbo,
make sure the power is off to the light. Either try and grab the edge of the base with a pair of needlenose pliers and twist out, or, take a raw potato and push it against the base and turn. It shoule turn the old base out.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-29-2010, 09:50 AM   #3
Rewards Points: 130
Insert needle nose pliers inside the remaining shell. Pull handles apart forcing jaws to grab/push against the inside and turn counterclockwise. I would stay away from using vegetables where tools are indicated. Just MHO.
Old 10-29-2010, 09:53 AM   #4
Rewards Points: 154
Too bad I was going to whip up an omlette to have with the potato, LOL!!! I'll give that a try when I get home, I better not have my wife around, she might flip the switch and fry me.................
Old 10-29-2010, 09:59 AM   #5
Rewards Points: 512
either make sure the power is off, or be damn certain that the needle nose pliers touch ONLY the sides of the bulb base NOT the sides AND the center.
Old 10-29-2010, 10:15 AM   #6
Rewards Points: 558
Well if she turns on the power you will have French fries if you use the potato method.
epson is offline   Reply With Quote
Old 10-29-2010, 11:01 AM   #7
Just call me Andrew
Rewards Points: 1,020
May as well just shut the breaker off first...
Andrew
secutanudu is offline   Reply With Quote
Old 10-29-2010, 04:06 PM   #8
Rewards Points: 154
Mission accomplished, no accidents, so where do I pick up my union card now that I'm certified?
Can I install a self-ballasted CFL bulb into a ballasted fixture? Daaavey Electrical 22 08-25-2010 08:52 PM
Light bulb in fan goes off and on ilyaz Electrical 2 07-19-2010 09:00 PM
Light Bulb Burst Mark Harvey Electrical 4 02-20-2010 12:54 PM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
Flourecent light bulb question shadango Electrical 7 06-28-2008 08:28 PM
