Light Bulb Burning Out - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 10:23 PM   #1
Hey guys,
I am having a problem with one light bulb burning out. It is on a circuit of 3 bulbs in series and a toggle switch in the kitchen, all bulbs are those energy saving spiral bulbs. When the switch is flipped, there is a delay between each bulb lighting. From reading a little bit on these type of bulbs, I halfheartedly attribute this behavior to a capacitive and/or inductive behavior of the bulb.
So why does this one bulb burn out every few months to a year while the 2 other bulbs last much longer? Anything to fix this?
GerGa is offline   Reply With Quote
Old 07-25-2011, 11:20 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,098
You say there are three lamps in series !
Are you sure there in series ?
If they are indead wired in a series configuration (doubtful)
then this is your problem !
But I cant see how they are
cause they would have to 120v / 3
thats 40v each lamp.
I have not head of 40v CFLs.
Dodgy sockets or cheap lamps most common problem.
But vibration and heat can also play a part.
CFLs do not like heat build up.
dmxtothemax is offline   Reply With Quote
replce a high cealing light bulb shyam Electrical 1 04-12-2011 12:44 AM
broken light bulb out of reach over stairs cmelichar General DIY Discussions 5 05-27-2010 05:29 PM
broken light bulb in ceiling over stairway cmelichar Electrical 4 05-27-2010 03:49 PM
Recessed light - lamps burning out rjniles Electrical 2 04-02-2009 05:23 PM
Flourecent light bulb question shadango Electrical 7 06-28-2008 09:28 PM
