Old 05-13-2011, 05:48 PM   #1
Light Breaker keeps tripping
Hi Guys I hope you can help me
I've tried replacing my bedroom light from a standard celing rose to a 3-spotlight bar light.
On my first attempt I got the light working with no problems however I wasn't happy with the position I had installed it as it wasn't perfectly straight, so I adjusted the bracket and connected the light backup as soon as I tried to turn the light on the breaker tripped. I checked my wiring and decided that the wires were probably a bit tight now tht the bracket was moved slightly so I've made the hole bigger and reconnected everyting and again the breaker trips. I tried moving the light back to the original 'not straight' position but still no luck!
Whats worse is that even with no light installed - just the bracket. i cant get the breaker back on? The bracket is metal so could it be that it is effecting the cables somehow?
Any help you can give me would be much appreciated before I give up and call out an electrictian!
Robbie
robbiecookie101 is offline   Reply With Quote
Old 05-13-2011, 06:01 PM   #2
Licensed electrician
If the breaker won't stay on you have a short. Check to make sure a hot wire is not in contact with the bracket or box.
Old 05-13-2011, 07:55 PM   #3
Missouri Bound's Avatar
Pull the fixture back down (breaker off) and look for any discoloration where the wire touches the bracket or the box itself, if metal. Is this light contollled with a wall switch? If so, you may have wired it incorrectly. Please do all of your inspections with the power off. If you can't find the proplem, call someone qualified to do so.
Old 05-14-2011, 06:13 AM   #4
Hi Both
Thank you for your replies. I can confirm that I managed to work out the problem.
Basically I had wired the wrong cable for the switched live.
Thanks again!
Robbie
Tags
breaker, light, trip
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 02:24 PM
