Light Box For Vinyl Siding (electric ?) - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 06:08 PM   #1
Rewards Points: 101
light box for vinyl siding (electric ?)
this may sound really stupid but... so I removed my old siding and replaced much of the sheathing (rotted), them I wrapped and sided the house in vinyl with those cute little "stand off" light box thingys. So now to my question: was I supposed to install a light junction box (blue round type) behind the vinyl nail on box? So far I'm done with the siding and just drilled a hole in the sheathing from inside... I don't have the fixtures yet so I'm not really sure how they are supposed to mount to a flat piece of plastic, and where do i put the wires? just behind the plastic against the house? that doesn't seem right. thanks for any input. 1
1dumbquestion is offline   Reply With Quote
Old 01-04-2012, 06:18 PM   #2
Rewards Points: 734
There are different style mounts for lights. Your connections do need to be in a box, or the equivalent.
Check this:
http://www.amazon.com/Arlington-8141.../dp/B002W6ZOCO
What do you have now? Just a blank front?
AandPDan is offline   Reply With Quote
Old 01-04-2012, 06:20 PM   #3
Julius793's Avatar
They make special boxes that mount right onto the siding that sit very nicely and the wiring goes in it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-04-2012, 06:30 PM   #4
MarginallyQualified
Rewards Points: 2,464
one half goes onto the sheathing with the wire poked out inside it...
the other half goes on AFTER the siding is done when the device or fixture is mounted.
hth
Old 01-04-2012, 06:31 PM   #5
Rewards Points: 12,818
Lowes and any real siding supply will have siding blocks with the wiring box built right in to it.
For a light it mounted horizontal, an outlet it goes vertical.
Nail it on wire it done.
Old 01-04-2012, 06:38 PM   #6
Julius793's Avatar
hth
What I'm talking about is what the first guy posted
Old 01-04-2012, 06:39 PM   #7
Rewards Points: 101
Check this:
I don't know how to post a pic but it's what I got from my siding supply house to mount lights, it nails to the sheathing then you install the vinyl then a trim ring pushes in place, it is flat in the front with a hole to feed wire through. it seems pretty typical as I see them on everyhouse I drive by with this type of siding, I just don't know if they have a box underneath or not... sound like I need one and I can still put one in it will just be a little bit of a hassle. thanks, 1
Old 01-04-2012, 07:09 PM   #8
This is the easyest one to install.
http://www.lowes.com/pd_89145-271-EB...%7C1&facetInfo=
If you have a larger light then there is a trim ring they also sell that replaces the supplyed trim ring to make it look better.
Old 01-04-2012, 07:09 PM   #9
MarginallyQualified
when you put the two pieces together... that is what creates the box.
Old 01-04-2012, 07:14 PM   #10
What I think Tarheel is talking about is what's called a split box. Not the one to use for this job. It does not make a box to make connections.
Works fine for where sill cocks come through the wall, condinsate drains, flush mounted outlet boxes ect. but not for a light fixture.
Old 01-04-2012, 07:19 PM   #11
Rewards Points: 101
Hope this works, this is what I have already installed. The trim is just to cover the edges of the cut vinyl, I don't really know how it makes a box. I may be making this more difficult then need be. sorry, 1
http://www.accentbuildingproducts.co...untblock-s.gif
Old 01-04-2012, 07:44 PM   #12
MarginallyQualified
this is what I'm referring to (sort of)...
(mine both sides hav boxes that sleeve together)
Old 01-04-2012, 07:55 PM   #13
The one Tarheel showed will work and be better then the one you have on there now. The one I showed that sold it Lowes will have holes to attach the lamp directly to it.
The one you have on the house has no pretty way to mount the light to it.
That's the old style.
Old 01-04-2012, 08:11 PM   #14
MarginallyQualified
In a pinch (like after the siding is up)...
2 or more of those flanges can be trimmed down so the box can be forced to slip into place. When no one is looking I've even seen screws driven through the back of them too. shh!
Old 01-04-2012, 08:16 PM   #15
Licensed electrician
Rewards Points: 1,020
You can cut a hole for a 1 1/2" deep box to contain the splice and provide mounting holes for the fixture.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 03:29 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
