Old 01-13-2013, 09:02 AM   #1
Light box
My father in law took down a track light fixture so I didn't see how it was wired. I have a ceiling mounted light box with 2 wires coming into it. One is a 3 wire. The other is a two wire. It seems one of the wires is "switched"(the power to it goes off/on with the switch), and the other wire has constant power
craig o is offline   Reply With Quote
Old 01-13-2013, 09:06 AM   #2
Light box
Now wondering how to hook up a regular 2 wire light fixture
Old 01-13-2013, 09:19 AM   #3
Light box
Are you counting the ground as the third wire?
What color are the wires?
Pull out the switch a tell us how may wires are attached to it. (do not count the bare ground.
Kill the breaker first!
Old 01-13-2013, 09:22 AM   #4
Child Alert! Pull Up!
fltdek's Avatar
Light box
Can you post a picture of the ceiling box with wires, as well as a picture of switch, pulled out away from its box so we may see the wire configuration? Thanks.
fltdek is offline   Reply With Quote
Old 01-13-2013, 10:08 AM   #5
A "Handy Husband"
rjniles's Avatar
Light box
If the swiched wire is red, do this:
Connect the 2 wites together, connect the 2 blacks together. Connect the white fixture wire to the 2 whites, connect the black fixture wire to the red.
If your colors are different, post what you have.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-13-2013, 12:20 PM   #6
Light box
You have a 2 wire that is a 3-wire and a 2-wire?
What???
hammerlane is offline   Reply With Quote
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 04:00 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
