-   -   Light box (http://www.diychatroom.com/f18/light-box-168977/)
craig o 01-13-2013 08:02 AM
Light box
My father in law took down a track light fixture so I didn't see how it was wired. I have a ceiling mounted light box with 2 wires coming into it. One is a 3 wire. The other is a two wire. It seems one of the wires is "switched"(the power to it goes off/on with the switch), and the other wire has constant power
craig o 01-13-2013 08:06 AM
Now wondering how to hook up a regular 2 wire light fixture
joecaption 01-13-2013 08:19 AM
Are you counting the ground as the third wire?
What color are the wires?
Pull out the switch a tell us how may wires are attached to it. (do not count the bare ground.
Kill the breaker first!
fltdek 01-13-2013 08:22 AM
Can you post a picture of the ceiling box with wires, as well as a picture of switch, pulled out away from its box so we may see the wire configuration? Thanks.
rjniles 01-13-2013 09:08 AM
If the swiched wire is red, do this:
Connect the 2 wites together, connect the 2 blacks together. Connect the white fixture wire to the 2 whites, connect the black fixture wire to the red.
If your colors are different, post what you have.
hammerlane 01-13-2013 11:20 AM
1 Attachment(s)
You have a 2 wire that is a 3-wire and a 2-wire?
What???
