Lighbulbs Flicker From Time To Time - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 08:25 AM   #1
Rewards Points: 12
Lighbulbs flicker from time to time
I have two ceiling fans with lights on the ground floor. The lights operate on the wall switch and the fans can be turned on and off by pulling a chain on the fixture. They have been in the house maybe 20 years. I used to have compact florescents in them but started having problems with flickering/crackling so I put in incandescent bulbs recently to rule out problems with CF bulbs. They worked fine for a week, but now these have started to flicker sometimes. (irrespective of fan usage) The fans seem to work without problems. Can someone tell me what is going on? I don't really know electricity, but I worry about a short and fire and am hesitant to turn them on any more.
hubbard is offline   Reply With Quote
Old 10-26-2012, 08:28 AM   #2
Rewards Points: 14,312
Are they the only lights in the whole house that flicker?
I'd be checking for a loose connection.
hubbard (10-26-2012)
Old 10-26-2012, 08:50 AM   #3
Rewards Points: 12
I had a problem with a ceiling mounted fixture upstairs in the stairway but that seems to have stopped. It is operated by two wall switches (one upstairs, one downstairs) There are actually two fixtures on this switch and the one fixture mounted on the wall no longer lights but I'm not sure if that is due to the bulb as I cannot reach it to change it out. The wall mounted fixture bulb hadn't worked for years so I thought it had a dead bulb. I was concerned last year when it suddenly came on with the ceiling mounted fixture and flickered but it hasn't come on since.
Old 10-26-2012, 09:04 AM   #4
You have some loose connections some place, most likly a nutral wire.
Not a good thing and yes it can be a fire hazzard.
Old 10-26-2012, 09:06 AM   #5
DIY staff
Rewards Points: 7,174
Like Joe said---loose conection---if the both flicker at the same time----remove the cap that hides the wires --and replace the wire nuts after you make sure the wires are properly stripped and twisted---
If the lights flicker randomly--one on and the other off---it could be that the socket connection is fatigued or compressed--
The contact in the bottom of the socket can often be pried up a bit to give good contact between the bulb and socket---
Kill the power before you try to fix a socket----always kill the power at the breaker-----
Old 11-05-2012, 03:42 AM   #6
CFL's tend to flicker all sow from time to time. I forget the condition but try replacing them with incandescent bulb's for a short time see if it fixes the probblem.
rodm1 is offline   Reply With Quote
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 08:13 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 04:13 PM
Lights flicker when Central AC Comes on Kutz Electrical 6 08-27-2011 12:31 AM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 02:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
