LIcensing Requirements For Installing A Light Fixture. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 08:16 PM   #1
LIcensing requirements for installing a Light Fixture.
Do I need to be a licensed electrician to put in a light fixture in one of my friends home? They live in Saint Paul Minnesota.
FunkyMonkey is offline   Reply With Quote
Old 12-02-2010, 10:22 PM   #2
Electrical Supplier
Rewards Points: 150
Contact your AHJ.
General rule is that if you DONT pull a permit for the work you DO NOT need to be an electrician (licensed) To pull a permit you MUST be a licensed contractor. So the question becomes does the work require a permit?
Again, only your Local Inspector can answer that.
LyonsElecSupply is offline   Reply With Quote
Old 12-03-2010, 11:14 AM   #3
Rewards Points: 82
It really is not something even a licensed electrician would pull a permit for. The permit cost would make this simple job to expensive to do.
I am not telling you that you do not need a permit. I am telling you I would not pull a permit to do this in either your house or my house.
Old 12-03-2010, 02:45 PM   #4
Rewards Points: 3,130
Nonsense (at least everywhere I've ever lived). I'm not a licensed anything, and have pulled several permits for work I've done myself. My wife and I are currently building our own log home, and I pulled all the permits for that. We subbed the HVAC but have done the electric, plumbing, and most everything else ourselves.
Old 12-03-2010, 04:57 PM   #5
Just use caution, as I believe a homeowner can do a fair amount of projects on their own residence, but the rules tend to a change a bit when you start working on someone else's property. Just something to keep in mind.
H8Mondays is offline   Reply With Quote
Old 12-04-2010, 01:00 AM   #6
" Euro " electrician
frenchelectrican's Avatar
This part is a touch and go on this one to replace it only genrally it don't need permit but to add new one where it did not then yes you will need permit however in Twin city the codes will varies depending on which quadant area you are in so best thing is check with your local inspector office for latest info.
Just keep in your mind the rental units { house or apartment } will useally required a electrician to deal with it { after talk to landlord first due there are a bit of rules to cover on this matter}
Merci.
Marc
Old 12-04-2010, 09:29 AM   #7
Electrical Supplier
Rewards Points: 150
In the context he was using YOU MUST be a licensed electrician.
Homeowners DO NOT need a license to pull a permit.
I have got around this on doing a service upgrade by "helping" the homeowner perform the service change......
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
Replaced Light Fixture, additional wire? froddan Electrical 11 11-17-2009 11:55 AM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 04:50 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 09:20 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
