Old 03-15-2010, 09:40 PM   #1
Leviton timer installation - ok with whole house fan?
This weekend I installed a whole house fan in the attic. it comes with a switch for high and low settings. I also purchased a Leviton electronic timer switch (6161T). My plan was to hook the two up together and have the timer feed power to the switch. Here are my questions:
1. The switch says on the packaging: "ideal for heat lamps, indoor and outdoor lighting" and "allows you to connect standard incandescent lighting only" - Can this be used to run power to my 30 inch attic fan?
2. The switch has 2 black wires and a ground. Assuming I can use this with my fan I wanted to confirm I have the wiring correct: Line to either black, second black to the switch, neutral to each other. Is that correct?
Thanks.
feign3 is offline   Reply With Quote
Old 03-15-2010, 10:01 PM   #2
Not suitable for heavy motors.
brric is offline   Reply With Quote
Old 03-15-2010, 10:54 PM   #3
What timer(s) would you recommend for this type of application then?
Old 03-15-2010, 11:00 PM   #4
What is the make and model number of the unit?
Old 03-15-2010, 11:11 PM   #5
Air Vent - WH302BD
I have a dial type timer (Woods 59717) purchased from Menards but my wife wanted something more 'stylish'. Hopefully there's something that fits the bill.
Old 03-16-2010, 09:11 AM   #6
I searched the Air Vent site and could not find the amperage or horsepower rating on the belt drive model you have. The leviton 6161T would not be applicable but I have located some similar style timers some rated up to one horsepower, most notably Intermatic brand.
Old 03-16-2010, 01:40 PM   #7
The whole house fan I installed yrs ago ( dayton (Grainger)) had a 2 speed with an intermatic timer that came with it.
It was a spring wound type 12 hour , worked great.
http://www.intermatic.com/products/t...%20timers.aspx
High Gear is online now   Reply With Quote
Old 03-16-2010, 02:53 PM   #8
Household Handyman
I don't have the specific answer for you but would like to advise that timers and motors must be matched. As you have seen, motors are not light bulbs. David
Old 03-16-2010, 06:16 PM   #9
Thanks for your input everyone.
I did find a timer rated at 3/4 HP at home depot today. The fan itself is 1/3 HP so I would assume this will do fine.
Thanks again.
More On This Topic
Learn how to connect black wires when installing a ceiling fan in this free home improvement video. Read More »
If you've had trouble insulating your home from hot summer weather, you might consider investing in an attic fan. While air conditioning can help to cool air in the livable portions of your home, most attics do not have air conditioning. After hours of... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
replumbing an old house simonfrog Plumbing 5 05-29-2009 06:44 PM
fibre optical cable house installation archierex PC Repairs & Upgrades 16 03-20-2009 10:37 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 09:56 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
