Leviton Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 12:29 PM   #1
Rewards Points: 340
leviton switches
Why Did Leviton eliminate the #2 phillips head screws on their outlets/switches?
kt82 is offline   Reply With Quote
Old 01-05-2013, 03:17 PM   #2
Rewards Points: 6,652
Who knows. Have a picture as an example?
Old 01-05-2013, 03:25 PM   #3
Electrical Contractor
kbsparky's Avatar
Maybe they are using R2 instead?
Edit to add: They are R1.
From the Leviton web site:
Large head triple-drive combination screws (Standard, Phillips, Robertson) for fast wiring installation
Looks like I am partially correct. They do have R2 capacity, but not at the expense of Phillips.
Edit to add: R1, not R2.
-KB
Old 01-05-2013, 04:26 PM   #4
Rewards Points: 340
i stepped down to a #1 phillips and got them off . I guess i 'll have to add a "robertson " to the tool box
What is the advantage of th Robertson?maybe Leviton has the patent on the design?
or better yet not buy any more Levitons
Old 01-05-2013, 04:54 PM   #5
kbsparky's Avatar
P&S is also using the Robertson screwheads. But they are R1 (and come to think of it, Leviton is also using R1).
Get used to it.
-KB
Old 01-05-2013, 06:29 PM   #6
jbfan's Avatar
Rewards Points: 530
Milwaukee makes An 11 in 1 screwdriver with the #1 and #2 tips that are really good.
Milwaukee 48-22-2113 11-in-1 ECX Multi-Tip Screwdriver
Old 01-05-2013, 07:17 PM   #7
Master Electrician
Rewards Points: 3,916
Less cam out with Robertson's. I use them all the time on Leviton devices.
brric is online now   Reply With Quote
Old 01-05-2013, 07:46 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Pretty much everyone makes these. I am a convert myself. Always thought they were lame, now I can't be without one. I keep one in my personal truck, kitchen drawer, garage tool box, etc.
Old 01-05-2013, 07:48 PM   #9
Square heads (Robertson) is a world standard from what I have seen. For once we are taking a good example from the rest of the world instead of going off on our own (ie: std vs. metric).
Old 01-05-2013, 08:17 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Robertson is fine with me.....if your into wood working, a many of the screws now are Robertson....
Old 01-05-2013, 08:29 PM   #11
jbfan's Avatar
Rewards Points: 530
http://www.toolreviews.ca/reviews_ha...2_2113/040.JPG
This what I like about the Milwaukee bit.
I'm sure others make it.
I don't know how to post a pic.
Old 01-06-2013, 02:29 PM   #12
" Euro " electrician
frenchelectrican's Avatar
Very easy to post the pic so use the photo icon ( Yellow square box above the screen ) that the one you click on then instert the link in there and ya good to go.
I have used the Robertson as well over here in European side we do like it as well.
I will post the photo for ya.
Merci,
Marc
Last edited by frenchelectrican; 01-06-2013 at 02:30 PM. Reason: add JBfan's link for the photo in here.
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 12:37 PM
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Wall Switches - with unknown termination cbjr Electrical 6 02-21-2012 08:15 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
