Leviton Structured Media Center - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 08:30 AM   #1
Rewards Points: 77
Not sure if this is an electrical or a PC post.
I wanted to install a 28" leviton SMC panel in my basement, horizontally on the wall insted of the traditional vertical way, cant find anything that says i can or cant, it would save me a ton of work to do it horizontally. Has anyone done it or seen it this way?
bryan1282 is offline   Reply With Quote
Old 04-16-2012, 08:57 AM   #2
Master Electrician
Rewards Points: 3,826
IMO it's likely the modules would interfere with the incoming cables as the ko's are usually on the shorter ends of the panel. Operationally I don't think there would be an issue, just would look funky.
brric is online now   Reply With Quote
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 06:56 AM
Battery backup to structured media panel. jr219 Electrical 17 10-26-2011 10:26 AM
Leviton Structured Panel box tb582 Drywall & Plaster 0 12-27-2009 04:50 PM
Setting up Media Center: Need Advice tripower Home Theater 2 09-23-2009 11:11 PM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
