Old 06-13-2007, 10:05 PM   #1
Extreme DIY'r Adk's, NY
Leviton/P&S interchange
Can someone confirm...
A duplex cover plate for a 20a commercial leviton receptacle will fit a 20a commercial Trademaster Pass & Seymour receptacle? They are standard shape right...may vary in thickness, etc.?
thanks!
crecore is offline   Reply With Quote
Old 06-14-2007, 05:10 AM   #2
What matters is that the NEMA configuration of the recepicles is the same.
Master Electrician
jwhite is offline   Reply With Quote
Old 06-14-2007, 06:24 AM   #3
right, and if it IS, than the plates would interchange... this IS what I was asking.
Old 06-14-2007, 06:58 AM   #4
RippySkippy's Avatar
I've not used those specific ones, but I would bet they're the same.
RippySkippy is offline   Reply With Quote
Old 06-14-2007, 08:07 PM   #5
let me rephrase this. Check the nema configuration of the recepticle and the cover. If they are the same, it will work.
I have no way of knowing, based on the info you provided, what the nema config is for the parts you are talking about.
Master Electrician
Old 06-14-2007, 09:41 PM   #6
For the record, I tried it and they do.
15amp Leviton, 20a Leviton CR20a commercial and CR20a trademaster P&S all seem to interchange.
