Let Me Know If This Is A Bad Idea... - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2009, 04:52 PM   #1
Let me know if this is a bad idea...
I really don't know much about wiring and stuff which is the main reason I'm here.
I'm trying to wire 9 150watt-max outdoor lampholders together to hold 9 23watt compact fluorescent light bulbs.
The box that the light come in say do not use more than 25 bulbs on a single 20 amp branch circuit so I figured this would be feasible.
Could this be as simple as splicing all 9 lampholders together to an extension cord?
If my math is correct that would be 207 watts running through the cord.
What worries me is would splicing 9 outlets together make the light be dim or if one broke would they all go out.
Any information would be helpful. I hope there's a way to do this because I think it would be way easier than running 9 trouble lights out to my yard...
Subgen1us is offline   Reply With Quote
Old 08-22-2009, 04:59 PM   #2
It's only 575w for a ~2400w circuit, so maybe these CFLs pull a large surge current on startup.
Yes, but the NEC might say otherwise
and 207/120 = 1.7A
No, they'd all be in parallel.
See the heading "Parallel circuits" in
http://en.wikipedia.org/wiki/Series_...allel_circuits
Old 08-22-2009, 06:00 PM   #3
Electrical Contractor
kbsparky's Avatar
What is the final application of such a setup? Extension cords are not approved as permanent wiring methods ....
-KB
Old 08-22-2009, 06:12 PM   #4
It's going to be a portable yard light that I can use when working outside.
I know I could go get an el cheapo hallogen light to move around but I already have all the supplies to make one myself. Therefor I wouldn't need to spend any cash.
The extension cord is rated at 13A 125V 1625W.
Think I should leave the plugs at the end or should I snip it and end it with a lampholder?
Thanks for the info Yoyizit.
Insulation Idea buildingahomeCO Building & Construction 12 07-28-2009 10:57 AM
Cheap temporary kitchen flooring idea. ember64209 Flooring 9 01-10-2009 11:45 AM
Is this a bad idea??? drillbit Building & Construction 3 08-19-2008 09:14 AM
Idea for kitchen peninsula acomiskey Remodeling 3 05-17-2008 02:12 PM
Carpet Idea...Will It Work? Topazprincess77 Flooring 1 03-19-2008 10:47 AM
