Length Of A Wire Run. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 01:41 PM   #1
Length of a wire run.
How far can I run 14ga wire in conduit to serve 2 150 watt spot lights.
I want to run wire 170 feet through metal conduit to serve 2 150 watt spot lights is 14ga sufficient or do I need 12ga. Would it make a difference if I used only 1 150 watt light?
LawandOrder is offline   Reply With Quote
Old 06-10-2010, 01:45 PM   #2
14g wire will work for 170' & 300w load, 2% voltage drop at that distance
I'd use CFL's myself
Old 06-10-2010, 01:45 PM   #3
Licensed Pro
If the two lights are all that are on the circuit, #14 will work, but for a little additional expense, I would go ahead and run #12.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 09:55 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
