Length Of Run? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 02:20 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by Sfeyelectric View Post
Can not exceed 3.6 volt drop on 120
Can not, or should not?
Do you have a code citation for this?
Clue: It's not 210.19(A)(1) FPN No. 4
Speedy Petey is online now   Reply With Quote
Old 01-03-2011, 04:24 PM   #17
Originally Posted by DUMMYDIYer View Post
Is it safe to use a 200foot run of 12-2 with ground in a 1/2 inch conduit to run all the power needs of a 2005 or newer full sized expensive motor coach. I moved in a place and we are both on the same meter and the power bill is sky high and I use very little power and they are and elderly retired couple home all day is this because of the voltage drop to them or something else.
I've RV'd for 30 years now. I think you'll find your motorhome is 50amp on 120volt if it's a newer model, check your owners manual or dealer. Also if this is a long time, "or very often," hook up, best to get away from extension cords and go with a proper box to box hook up, chance of burning up A/C or other items.
collector42001 is offline   Reply With Quote
Old 01-03-2011, 04:52 PM   #18
I've never seen a 50A-120v motor home hook up. Only 30A-120v and 50A-120/240v.
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 05:51 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
Maximum base board loop length Mike Warner HVAC 1 04-30-2008 11:48 PM
