Old 05-29-2011, 10:56 PM   #1
Wire Chewer
Red Squirrel's Avatar
is it legal to use backstab + screw at same time?
I am wiring 4 outlets in a 4 bang box and have two circuits coming in and it's not a MWBC so I broke both tabs off 4 of the outlets. I realized it was physically impossible to wire this because of all the pig tails required. I ended up just making it one circuit and just striped enough wire so I can extend it under both screws. Then I started thinking, could I not just wire to a screw, then use backstab to go to the next outlet? Or is this a no no? I know backstabs are normally frowned upon and I normally don't use them, but this is a situation where I can see them being useful perhaps.
Old 05-29-2011, 11:09 PM   #2
I don't know of any code that would be violated.
hayewe farm is offline   Reply With Quote
Old 05-29-2011, 11:11 PM   #3
Licensed electrician
I think I would just run 4 pigtails of the incoming and install new receptacles. Much simpler.
Old 05-30-2011, 12:36 AM   #4
zpm
yeah, right
Is there some specific reason you need the top/bottom of each recept on a different circuit? Why don't you wire two recepts from circuit #1, and the other two recepts from circuit #2. You don't need any pigtails for that, just some jumpers.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 05-30-2011, 01:04 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
is it legal to use backstab + screw at same time? -YES ,but ....
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-30-2011, 11:27 AM   #6
Wire Chewer
That's what I ended up doing, but thought of this after the fact, guess at the end I still accomplish the same thing and less hackish.
Old 05-30-2011, 01:22 PM   #7
Newbie Bill
I'm curious what you are using the 4 outlets in a 4 gang box for?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-30-2011, 01:33 PM   #8
Only on 15 amp circuits
electricman is offline   Reply With Quote
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Wow, I got money coming beenthere Off Topic 12 01-21-2010 02:28 PM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 09:18 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Ground screw in 4" box fw2007 Electrical 8 10-05-2007 04:07 PM
