Is It Legal To Run Wires On The Ground, In Conduit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 07:07 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by A Squared View Post
Rigid Conduit requires a bending machine.
nah, just a 270 pound electrician and a hand bender. Ideal lists their benders (the iron benders, not the aluminum) for rigid conduit as listed below.
Conduit Type and Size/ Bender Only Cat. No./ Handle Only Cat. No./ Bender & Handle Cat. No.
1/2 in. EMT 74-001 74-019 74-026
3/4 in. EMT, 1/2 in. Rigid and 1/2 in. IMC 74-002 74-019 74-027
1 in. EMT, 3/4 in. Rigid and 3/4 in. IMC 74-003 74-020 74-028
1-1/4 in. EMT, 1 in. Rigid and 1 in. IMC 74-006 74-021 74-034
Old 02-21-2011, 08:09 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I'll see what HD has, but think I will settle with the EMT and buy the bender tool and run a couple individual EMT runs. Will make for a neat installation too. Right straight down from the panel, one 90 bend and on the ground to the rack, then to the plug boxes. The ground part will most likely be covered by some kind of raised walking surface. I'm not ready to do this any time soon but at least I have an idea now of what to do.
Anyone familiar with CEC and if having plugs directly on the floor is ok? That's the only part I'm not too sure on now.
Old 02-21-2011, 08:43 PM   #18
i found it easier to put twist lock plugs on the ceiling instead of regular ones in/on the floor
RTypeEman is offline   Reply With Quote
Old 02-21-2011, 10:02 PM   #19
iminaquagmire's Avatar
Rewards Points: 338
There is absolutely no reason for GRC in a residence unless you're running heavy machinery inside. EMT would do just fine in this situation. Try to bend 1 1/4 EMT by hand and you'll see the value of using more smaller conduits when available. Floor receptacle require floor boxes.
iminaquagmire is offline   Reply With Quote
Old 02-21-2011, 10:29 PM   #20
nap
You talking to me?
nap's Avatar
I have to agree. Not sure that rigid was actually recommended by anybody but no, you aren't going to need rigid or even imc. emt will be just find unless you have a habit of wearing one of these as you wander around your server room:
Old 02-22-2011, 02:59 PM   #21
Rewards Points: 212
Agree, EMT should work just fine. I only mentioned IMC and Rigid conduit to give the OP an idea of the different kinds of conduit, not to suggest that they were needed.
A Squared is offline   Reply With Quote
Adding ground wires michaelcherr Electrical 2 02-16-2011 08:16 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 02:17 PM
Conduit through garage to house. Max wires? RyanD Electrical 12 08-02-2009 05:12 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
running wires in a conduit analogmusicman Electrical 50 07-13-2008 08:49 AM
