LED Strip Length? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 08:04 PM   #1
LED strip length?
I am going to edge my enclosed cargo trailer with single color, 3528 SMD LEDs.
I'm wondering what is the longest length I can run the strips for. 5meters is the longest length I can find but am hoping I can run 19.5ft. or 25 ft. all at once.
Anyone had experiences with these before?
Karpiel73 is offline   Reply With Quote
Old 04-29-2012, 08:51 PM   #2
Master Electrician
i just put up a 47' strip but that was off a 120v transformer and it was run at 24v. i can't see why you won't be able to find a manufacturer that will carry it in such lengths. The only issue is the cost. I would try an electrical supply or even a tuner shop may carry the stuff.
I should add that with LED's sometimes it's not the wire feeding it that limits you to what you can do it's the light itself. You may be able to feed the light from one point and go two directions from there. Two fifteen foot strips would be plenty i would assume.
andrew79 is offline   Reply With Quote
Old 04-29-2012, 10:17 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,860
The issue is total current draw. If the strip is too long, the total current will be more than the traces on the flexible PCB can handle. I know for the high-density 5050 LED strips you can't run more than one 5-meter section (about 8A) and even that gets very hot. Plan on multiple feed points.
mpoulton is online now   Reply With Quote
Old 04-29-2012, 10:34 PM   #4
I'll just keep it simple then and stick to 5 meters max for all the runs.
With that being said, should I have an in-line fuse in the power wire? I figured it out to be just over 25 meters of LEDs will be used. So @ .45amps/meter I would use (if need be) a 15-20A fuse?
Old 04-29-2012, 10:46 PM   #5
Oh and this is for a 12v system, all running off my SUV.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Bad or failed heat strip. Any ideas why. 50juan HVAC 25 12-04-2011 05:04 PM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 05:52 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 06:38 PM
