LED Recessed Lights New Build - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 07:33 PM   #1
listo's Avatar
Rewards Points: 93
LED Recessed lights new build
Do you install them before or after you put up the drywall on the ceiling?
If you use ones like this,
SMARSTAR 15W Warm White(3000-3500K) AC 110V 220V 7.09"x7.09"/180x180mm Recessed Square LED Ceiling Panel Light
http://amazon.ca/dp/B00DZLMXS8
Do you put the wires in a normal junction box up in the ceiling cavity?
coming from Saskatchewan, near Saskatoon
listo is offline   Reply With Quote
Old 09-16-2013, 07:44 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
These would not be legal to install in the US. I have a feeling it is going to be the same in Canada.
The Following User Says Thank You to k_buz For This Useful Post:
listo (09-16-2013)
Old 09-16-2013, 09:07 PM   #3
Solutions (handyman)
Rewards Points: 362
led lights
I agree with Buzz, I'd chack with a local lighting company (not just your Home Depot employee) or call a building inspector ans ask the questions. Even pot lights require special consideration when it come to installation ... clearance, coverings, insulation etc.. If your are shy, go to a H.D. and look at a current wiring guide and you should geet the information or a contact number. Do do anything along the lines you are thinking until you're sure. ... for safety sake.
Mark Harvey is offline   Reply With Quote
The Following User Says Thank You to Mark Harvey For This Useful Post:
listo (09-16-2013)
Old 09-16-2013, 10:49 PM   #4
listo's Avatar
Rewards Points: 93
Right on, I wasn't gonna do anything for awhile just in the beginning stages of looking
Old 09-17-2013, 08:59 AM   #5
Rewards Points: 718
i know they are not legal in canada (you could remove them if you sell house), but they install after drywall
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
listo (09-17-2013)
Old 09-17-2013, 09:41 AM   #6
listo's Avatar
Rewards Points: 93
So not legal in Canada not legal in US guess I won't buy those ones, thanks everyone
Old 09-17-2013, 10:36 AM   #7
Rewards Points: 718
for canada you need either cULus or CSA approval
be prepare to pay about 2-3 times the price of CE product only
listo (09-17-2013)
Old 09-17-2013, 10:54 AM   #8
listo's Avatar
Rewards Points: 93
So with The ones ill need to get its probably easier to put them up before the drywall like you would a normal light, then cut the drywall to fit around them?
Old 09-17-2013, 11:02 AM   #9
listo's Avatar
Rewards Points: 93
Unless its like this one
Globe Electric 90072 3-Inch IC Rated Energy Star Integrated LED Sleek Recessed Lighting Kit, White
http://amazon.ca/dp/B00A32T88U
Old 09-17-2013, 11:07 AM   #10
it is radically easier to put can lights up before drywall
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
listo (09-17-2013)
Old 09-17-2013, 11:14 AM   #11
Rewards Points: 140
(very basicly) i measured and cut the holes in a piece of drywall. installed the DW. then from above, i set the cans in. then nailed em to the joists.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
listo (09-17-2013)
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 11:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 02:58 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
How many recessed lights in small bedroom? cdcamaro9534 Electrical 1 01-08-2009 10:57 PM
