LED Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 11:35 PM   #1
LED recessed lights
How many LED 6 inch lights can you put on a new 15 amp breaker when it is rated at 9.5 per light?
dhad is offline   Reply With Quote
Old 01-24-2013, 11:39 PM   #2
Rewards Points: 148
9.5 watts?
badhaircut is offline   Reply With Quote
Old 01-25-2013, 01:39 AM   #3
MCB
sparky
Is 12 enough?
MCB is offline   Reply With Quote
Old 01-25-2013, 05:17 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
At 9.5 watts per light you could add 189 lights to a 15 amp circuit (1800 watts) per NEC code. Sure you want to that?
Coastal South Carolina
Old 01-25-2013, 07:27 AM   #5
Rewards Points: 150
I believe it depends on the maximum wattage rating of the cans you're using -- not the bulb you ultimately choose.
silversport is offline   Reply With Quote
The Following User Says Thank You to silversport For This Useful Post:
Jim Port (01-25-2013)
Old 01-25-2013, 07:53 AM   #6
A "Handy Husband"
rjniles's Avatar
He specified LED can lights. Ive only seen them come as a total unit not as an empty housing that you can install lamps into.
If he means regular recessed housings that will accept incandescent lamps, them he is limited by the rating of the fixture.
The Following User Says Thank You to rjniles For This Useful Post:
Old 01-25-2013, 08:20 AM   #7
Rewards Points: 150
I assumed the op was referring to something like the cree cr-6.
Old 01-25-2013, 05:21 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,354
If you want to follow "best practice" it should be based on
the maximum rating of the fixture, not the rating of the lamp
used at the time.
so if your fixtures are rated for 100w max
then you can use 18 lights maximum.
100w = 18.
75w = 24.
60w = 30.
remember at some later stage someone could change the lamps
without knowing any better.
thats why you go by fixture rating not lamp rating.
dmxtothemax is online now   Reply With Quote
Multiple recessed lights on two 3-way switches YellowBelly Electrical 6 11-27-2011 02:59 PM
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
How many recessed lights in small bedroom? cdcamaro9534 Electrical 1 01-08-2009 09:57 PM
