LED Puck Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 08:00 AM   #1
Rewards Points: 165
LED Puck Lights
Does anyone know of where to buy LED puck lights that I can recess into wall niches? They need to be hard wired and IC rated. The niches are going between wall studs so a 2" recessed can won't allow me to center the light in the opening due to space issues. I see a lot of LED puck lights out there, but I don't see anything on the manufacturers websites for them being IC rated. The niches will be aproximately 1' down from the ceiling, so the installed lighting in them will be in the wall insulation.Thanks in advance.
chronojosh is offline   Reply With Quote
Old 12-21-2012, 08:04 AM   #2
Rewards Points: 6,652
LED lights put out no heat, and majority work in retro-fit kits, that you use an existing can, and install the LED fixture. Check the German House rebuild thread over in Project Showcase. Scott may be able to give you info where he got his LED fixtures.
hardwire LED puck lights useless Electrical 2 07-31-2012 01:08 PM
Lights still dimming and flickerin Keisha34 Electrical 18 06-08-2012 11:14 PM
Hardwired under cabinet puck lights acerunner Electrical 2 03-11-2011 12:38 AM
Halogen under-cabinet puck lights - too HOT? vsheetz Electrical 14 03-24-2009 08:14 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
