Old 10-04-2010, 05:58 PM   #1
LED potlights for soffit of my garage.
I just redid the wall of my garage facing the backyard with stone. Now I would like to add some lighting to it. Was going to place LED pot lights in the soffit and point it down at the wall/stone. From floor to soffit it is only 8 feet so i figure mini pot lights will be sufficient.
However can I use the regular LED pot lights they sell for under cabinets? Or do i need something rated for outdoor ? This is what I was looking at purchasing for the job.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
the punisher is offline   Reply With Quote
Old 10-04-2010, 08:04 PM   #2
Wire Chewer
Red Squirrel's Avatar
Probably has to be rated for outside, and don't think they'd be bright enough anyway. I eventually want to add pot lights myself to my house and that thought came across, but don't think you could do that.
Old 10-04-2010, 09:26 PM   #3
Your #1 Electrician
They won't be bright enough but before that I wouldn't recommend that application of lighting for that wall.
I don't think you'll be pleased with all the shadows the stones will create...but then again, that might the look your going for....
My recommendation:
Place the LED flood light(s) in or on the ground and focus it on the wall.
Your#1Electric is offline   Reply With Quote
Old 10-04-2010, 09:41 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
I'd use regular 4" recessed cans with LED or CFL lamps.
Old 10-05-2010, 10:59 AM   #5
thanx for the tips guys. I will be buying a couple different ones and put them up temporarily to see which look/work better. As for going from the ground facing up unfortunately that application is not suitable for the area
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
