Led Lighting - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 12:04 PM   #16
so wiring an adapter to the power supply wouldn't be a problem?
soldering directly to the adapter prongs?
this option would cost around 40.
here's another which would be already wired for 120v...no driver on it...nearly the same price
http://www.ecologicsavings.com/120v-...-sizes-prices/
would this work? would any of these interfere with the sound of the record player?
SPIT is offline   Reply With Quote
Old 09-19-2012, 01:53 PM   #17
can you help me out and take a look at these.
i think i may go with this option. just need to confirm i can solder the adapter to the power supply without interference. these are 24v.
http://1000bulbs.com/product/65259/FLX-5050WW2403.html
http://1000bulbs.com/product/65131/FLX-FY2401000P.html
Old 09-19-2012, 05:13 PM   #18
if i buy a role like this-- http://www.amazon.com/Ledwholesalers...ledwholesalers
can i just cut it up and solder the wire downstream from an ac adapter/transformer.
the ones i linked above are out of stock so now looking at the role and this adapter-- http://www.amazon.com/Ledwholesalers..._bxgy_k_text_z
Old 09-22-2012, 01:12 PM   #19
Insatiable Learner
Rewards Points: 166
Smile
THIS one looks better. Another way you can find this type of lighting is to search for "Under Cabinet Lighting". Make sure it's in the right color temperature and it should be easy to install. Also make sure that they use 3M adhesive which will stick much better to where you put it.
AngelArs is offline   Reply With Quote
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 02:35 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 04:12 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
