LED Light Feedback - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 03:12 PM   #1
LED Light Feedback
I was wondering if anyone here knows anything about LED lights. Specifically, I'm curious if anyone uses 3000K T8 bulbs, or 3000K T4 bulbs at home. Do you like how the natural light looks, as opposed to the white light of other bulbs? I'd like to hear others' opinions before making a purchase. Thanks!
CuriousGeorge is offline   Reply With Quote
Old 08-14-2013, 03:21 PM   #2
Common Sense Common Guy
Rewards Points: 161
My opinion is that the 3000K LED bulbs look artificially "yellow" or "tan". Where I have installed LED bulbs in my home I have gone with 5000K, and my shop has 7600K T8 strip bulbs. I tend to like daylight anyway.
flasherz is offline   Reply With Quote
Old 08-14-2013, 03:47 PM   #3
Rewards Points: 2,638
I have a number of PAR20 lamps. Currently, I have halogen, CFL, and LED bulbs in close proximity, so I can readily make comparisons. Of the three, I like the light of the LED's the best. As the other bulbs burn out, I am replacing them with the LED. The LED I am using is the FEIT 5K bulb. I prefer the whiter light.
The reason I have all three types up is that they were all originally halogen. I wanted to replace them with something more energy efficient for a long time. My fixtures have a trim ring that snaps onto the bulb, so I needed true PAR20 shape and size. It was only a couple of years ago that I found a CFL that would (mostly) fit properly. And it was only last year that I found a PAR 20 LED that had true PAR 20 dimensions, and had a reasonable output (500 lumens).
SPS-1 is offline   Reply With Quote
Old 08-14-2013, 04:11 PM   #4
Thanks! I'm remodeling my kitchen at home and I decided I definitely want to use tube LED lighting, but I'm still deciding which length I should use, 24 inches or 48 inches. How long are your LEDs?
Old 08-14-2013, 04:32 PM   #5
I would make sure you get the bulb in an industry-standard size. If its one manufacturer's own special bulb, by the time you need to replace it, you might not be able to find a replacement bulb.
Old 08-15-2013, 09:49 AM   #6
Rewards Points: 760
im using some can led lights 7w, they are 4000K, i have other 6000K gu10 led and i dont like them they are almost blue light. i wont go over 4000K in future
carmusic is offline   Reply With Quote
Old 08-15-2013, 11:03 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Instead of using T4 or T8 'type' LED lights, I would either go more common Edison, GU24 or rope lighting.
Those T8 LED bulbs are real expensive...
The rope lighting has come a long ways and is very flexible (and I don't mean just flex) in how you use it.
Check out SuperBrightLEDS.com for some good info.
And...I would suggest going more in the 4000-5000 color range....
Old 08-15-2013, 02:11 PM   #8
Rewards Points: 150
I'm with carmusic... Thus far I like the 3000K. 2700K looks like a regular incandescent. 3000K is quite a bit cooler. Where we've put them in it really changes the feel of the room. Going even higher is an option but while they call it daylight that's not comfortable for in home light where you're used to things being warmer. If stark, crisp, or contemporary describe your style, move higher. If warm, comfortable or casual are your style, then a little warmer. For a shop? Of course you want bright bright there. That's different than say a living room.
It also doesn't hurt to buy a couple types and take them back if you don't like them.
SquishyBall is offline   Reply With Quote
Old 08-15-2013, 08:34 PM   #9
We like 3000K LEDs in the bathroom and kitchen where their whiter hue is an advantage but go with 2700K LEDs in all other rooms including all can lighting in the finished basement. 3000K lighting is just too harsh for most rooms in my (and my family's) opinion.
kwilcox is offline   Reply With Quote
Tags
led lighting
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 05:24 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
