LED Lamps For Landscape Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 03:49 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
LED lamps for landscape lighting
I have an existing landscape lighting system that uses halogen 12V lamps. Several of the lights are mounted in trees and are a pain to replace when they burn out. I would like to replace with LED lamps for longevity. The lights in question are 12 Volt, 20 Watt, MR16 base halogens.
1. What wattage LED's would I need to get the about the same level of light as the current 20 watt bulbs?
2. My system is 12 Volt AC. Most of the LED bulbs I see (on eBay or the like) say 12 volt but do not say AC or DC. Does this mean they have a rectifier built in and can be used on either a AC or DC system?
Thanks for any help you can offer.
Coastal South Carolina
Old 02-04-2011, 06:10 AM   #2
I think I would look at Lumens, rather than watts. Some LED lamps are more efficient than others.
That is my understanding. All mine are LED and run on 12VAC.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
rjniles (02-04-2011)
Old 02-04-2011, 09:51 PM   #3
Electrical Contractor
kbsparky's Avatar
Try this one: It will work on either 12 Volt AC or DC
-KB
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
