LED Dimmers Each Require A Dedicated Neutral? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2014, 11:04 PM   #1
LED Dimmers each require a dedicated neutral?
Hi Folks I need a little help. I'm redoing my kitchen and have one circuit breaker that feeds a daisy chain of 4 Lutron CF/LED Maestro & Diva dimmers - each dimmer controls a few LEDs Lights. Two of those dimmers also have a three way working with them. I've been having some weird flashing going on in which dimming one group of lights can cause another on a seperate dimmer to flash. I even have one set of halogens that can flash as well. Changes bulbs around to keep the same type on one dimmer has helped, but I can still have random flashing. I've changed out the dimmers as well - same thing. I've spoken to Lutron and the LED lights from Homedepot I'm using (Comercial Electric T41 Gimbles) are not on the Lutron approved bulb list. Since they are about $45 a piece and have had them for some time, I'd rather not return them . Lutron support has a recomendation to run a dedicated neutral to each dimmer and take apart the common neutral they all share between them. Since my walls are all open, I guess I'm going to have to do this, but I wonder does the neutral have to be in an insulated jacket, as it is in Romex? Any ideas on how to go about this in a code compliant way would be greatly appeciated.
Thx, John
johnsmo is offline   Reply With Quote
Old 06-30-2014, 11:33 PM   #2
Rewards Points: 6,652
Yes under the current NEC. 2012 to be more specific. You are getting the flashing, due to the dimmers, along with the bulbs. LED's like CFL's are very finicky on Dimmers. Even if the dimmer is labeled that it is fine with either of those two bulbs.
I would talk to Lutron about it. Their engineers are really good in getting in touch with you regarding this stuff. When you send an email, or call to speak to one.
Old 07-01-2014, 08:53 AM   #3
but how to run a neutral by itself?
Thanks for your reply. I will run a seperate neutral to each dimmer but how do i do that? Do i have to get a spool of 14 gauge white wire (15 amp breaker) and fun that or do i need it a more protective shielding? Could i run romex and use the black as well as long as i label it? I suppose the ground in the romex coukd not be used? I have 4 runs to make. I appreciate your help.
Old 07-01-2014, 09:37 AM   #4
Rewards Points: 3,396
good question.
The neutral is run with the ungrounded circuit conductor. So are you suggesting multiple neutrals to that one location?
Interesting.
If that run was in a conduit, that might be doable.
ritelec is offline   Reply With Quote
Neutral on a dead circuit teamo Electrical 10 12-11-2012 01:10 PM
Common Neutral in Jct Box??? PastorKramer Electrical 5 11-20-2012 06:10 AM
Need Neutral Connections - Installing Subpanel ctlu008 Electrical 10 01-01-2012 07:54 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
