LED Cabinet Lighting - Wire Ga. - Run Lengths - 12v Or 24v Driver - So Many ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 10:24 AM   #1
DIY Enthusiast/Renovator
Question
LED Cabinet Lighting - Wire Ga. - Run Lengths - 12v or 24v driver - So many ???
So I'm planning for some under cabinet lighting in my new kitchen. I had originally planned to connect 120 line voltage to a low voltage driver which would knock the voltage down to 24v: W.A.C. Lighting *> 24v Class 2 Remote Power supply
I was also going to use these type of led strip lights: W.A.C. Lighting *> INVISILED PRO - 24V Indoor
The driver says to use a min. 18 ga. wire so that is what I used. The wires originate in the basement, where the driver will be located, then go to the floor above under the wall cabinets. I have 4 separate runs from this driver to power the lights in 4 separate sections of the kitchen.
The wire lengths, before they are connected to any light, are approximately 7', 12', 14' and 16'. The length of led light strips i'd be putting in are a maximum of 2', 2', 4'-6" and 5' respectively.
Should I be worried about this setup in terms of the length of the wire being run?
Do I need to worry about the 18 ga. wire overheating?
What would happen if I use a 12v driver with 12v led light strips: W.A.C. Lighting *> Remote INVISILED Class 2 Power Supply & W.A.C. Lighting *>*12v - INVISILED
Is there any better options?
Thanks for all the help!
Read more: http://www.doityourself.com/forum/li...#ixzz2BSazQ0sU
roundbox52 is offline   Reply With Quote
Old 11-08-2012, 08:06 AM   #2
Anyone?
Tags
18 gauge , cabinet lighting , led
Installing under cabinet lighting trim? kcrossley2 Kitchen & Bath Remodeling 5 11-13-2012 08:38 PM
Kitchen Cabinet LED lighting Stevebr Electrical 2 06-29-2012 02:21 PM
under and in cabinet lighting fabian General DIY Discussions 2 10-10-2011 10:04 PM
Low voltage under cabinet lighting question fishacura Electrical 6 03-29-2010 06:57 AM
Under cabinet lighting TonyD Electrical 20 11-08-2007 06:00 AM
