LED Bulbs On A Dimmer Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 11:21 PM   #1
Rewards Points: 506
LED bulbs on a dimmer switch?
Does it work? Are there recommendations for/against?
jlmran is offline   Reply With Quote
Old 07-08-2012, 11:56 PM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 520
You have to dimmers specifically designed for LEDs or LEDs that are marked for use with dimmers.
LED are low voltage and therefore require a transformer to drop the voltage down from 120v. Transformers don't like being on a dimmer. That's why you need to KNOW if and how a LED light can be dimmed.
JulieMor is offline   Reply With Quote
Old 07-09-2012, 12:11 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The Commercial Electric Halo style LED trims work great with a standard dimmer.
Old 07-28-2012, 12:30 PM   #4
Lutron dimmer are great but you have to get a dimmable magnetic driver. They can be pricey. For a PMW dimmer, they can be installed after the non dimmable driver but most do not look that good.
Here's an install vid.
Rziegler is offline   Reply With Quote
Old 07-28-2012, 03:08 PM   #5
Master Electrician
With a regular dimmer an led will dim a bit then just turn off. Much of time you need a driver in the light capable of dimming the led or an electronic dimmer as stated previously. The system I'm currently installing requires 120v to the light and 0 to 10 volt control to operate the dimming function at the driver for each light. Do your research and find out what you currently have installed in your fixtures.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Replacing a dimmer switch with a regular switch for a ceiling fan RP DeMars Electrical 0 04-18-2012 03:25 PM
Cannot Get New Dimmer Switch Working Correctly BzowK Electrical 8 02-11-2012 04:13 PM
3 Way Dimmer Light Switch Problem psubaron Electrical 4 07-13-2011 08:08 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
