LED Ballast - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 09:07 AM   #1
Exclamation
LED Ballast
Hello, can anyone assist in providing a good source of which to obtain a replacement for the following ballast? This is for an 89w LED system.
I've found the following product although i am unsure if this is the correct socket type. Any input would be appreciated. Thanks
http://www.aliexpress.com/store/prod...483538474.html
dnote is offline   Reply With Quote
Old 09-12-2012, 12:53 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,908
It looks electrically compatible. If the connector is wrong, just cut the connector off the old one and install it on the new one.
mpoulton is online now   Reply With Quote
Old 09-12-2012, 07:56 PM   #3
I think i may do this, OEM unit lasted me less than 2 years and costs twice the price at $143. I just wanted to be assured this ballast will work.
Old 09-13-2012, 01:16 AM   #4
It doesn't appear to be a ballast. LED's need a constant current DC driver, which is sometimes called a ballast by analogy to the ballast used for a gas discharge lamp which serves a similar function. This does not do the same thing. This appears to be a plain DC power supply. The "ballast" part (constant current driver) would be in the fixture that is powered by this DC power supply.
Florescent ballast, commercial or residential? rjniles Electrical 183 05-13-2016 04:47 PM
Help replacing T12 Ballast hugocraft Electrical 36 12-21-2012 04:16 PM
New T5 Ballast causing Blinking gray0239 Electrical 3 01-05-2012 12:37 AM
T12 ballast to T8 c.bustle Electrical 5 07-10-2011 11:33 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 05:02 AM
