-   -   LED Ballast (http://www.diychatroom.com/f18/led-ballast-156595/)
dnote 09-12-2012 08:07 AM
LED Ballast
Hello, can anyone assist in providing a good source of which to obtain a replacement for the following ballast? This is for an 89w LED system.
http://forums.mikeholt.com/attachmen...tid=7393&stc=1
http://forums.mikeholt.com/attachmen...tid=7394&stc=1
I've found the following product although i am unsure if this is the correct socket type. Any input would be appreciated. Thanks
http://www.aliexpress.com/store/prod...483538474.html
mpoulton 09-12-2012 11:53 AM
It looks electrically compatible. If the connector is wrong, just cut the connector off the old one and install it on the new one.
dnote 09-12-2012 06:56 PM
I think i may do this, OEM unit lasted me less than 2 years and costs twice the price at $143. I just wanted to be assured this ballast will work.
mpoulton 09-13-2012 12:16 AM
It doesn't appear to be a ballast. LED's need a constant current DC driver, which is sometimes called a ballast by analogy to the ballast used for a gas discharge lamp which serves a similar function. This does not do the same thing. This appears to be a plain DC power supply. The "ballast" part (constant current driver) would be in the fixture that is powered by this DC power supply.
