Leaving Old Wiring In Place - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 07:59 AM   #1
Rewards Points: 365
Leaving old wiring in place
I've seen some older posts related to the topic but just want to check that nothing has changed.
In order to leave old wiring that is no longer going to be used in a wall what needs to be done? I'd assume both ends (or more depending on how the wire is routed) must no longer be in energized boxes, ends probably cut flush or capped. What else?
I'm moving some switches around and will not be able to remove the wiring that goes to the old switch box without having to do more work than I'd like to.
info2x is offline   Reply With Quote
Old 03-01-2013, 08:11 AM   #2
jproffer's Avatar
Rewards Points: 716
If both ends are disconnected, you can leave the wires in the walls...no problem. (or actually if just the source end is, but that would make it hard to reuse whatever devices they were connected to )
jproffer is offline   Reply With Quote
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Fire Rated Wall? Need to place structured wiring panel. RICKM15752 Building & Construction 0 04-20-2011 12:21 AM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 09:03 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
