Old 01-31-2013, 10:32 PM   #1
Leaving an led light on forever
I am looking to illuminate my garage so it is never dark in the garage. Nothing real bright, just enough to easily move through the garage to maybe grab a soda or something at night. I installed the motion activated dusk to dawn night lights in the bedrooms, and the motion activated dimmer switches in the bathrooms, which I love . The night lights actually come on during the day through motion , not a big deal. Some of the issues I want to avoid are a light coming on full blast in my den late at night. Or walking by a light during the day and having it come on 40 or 50 times a day. So what I am thinking is just to wire a 40 watt led bulb in my garage that is hot all the time. I will not have to deal with it coming on every time I walk out to the garage. No dimmers no dusk to dawn. I was reading it should only cost about 8 dollars a year to run. Any suggestions. http://www.thesimpledollar.com/2009/...in-the-future/
paintdrying is offline   Reply With Quote
Old 01-31-2013, 10:44 PM   #2
MCB
sparky
You'd be able to see a 40W LED from the end of the street... wow.
MCB is offline   Reply With Quote
Old 01-31-2013, 11:50 PM   #3
I think he means 40W equivalent. Are you asking for bulb suggestions or for how you would wire it in?
info2x is offline   Reply With Quote
Old 02-01-2013, 12:21 AM   #4
i think he is just looking for confirmation that this is a decent idea, sorry not going to state my opinion, though i might think about doing this kind of thing myself.
redman88 is offline   Reply With Quote
Old 02-01-2013, 08:55 AM   #5
For this purpose, I simply use a couple of night lights. These are generally enough to move about. And they cost pennies per year to operate.
oberkc is offline   Reply With Quote
The Following 2 Users Say Thank You to oberkc For This Useful Post:
dougp23 (02-01-2013), drtbk4ever (02-01-2013)
Old 02-01-2013, 08:59 AM   #6
Yeah, basically asking if this sound ridiculous. I just want something very simple that will work. They make these dusk to dawn sensors that just screw in under the bulb so wiring is a snap. It is hard to explain but certain things I find very annoying. I want a light in a high traffic area that would be almost natural. But I can not have my electric bill going up from it.
Old 02-01-2013, 09:40 AM   #7
I'd be inclined to simplify the lighting situation by purchasing a 2 pack of LED night lights and if that wasn't quite enough light add 2 more.
Fairview is offline   Reply With Quote
The Following User Says Thank You to Fairview For This Useful Post:
J. V. (02-01-2013)
Old 02-01-2013, 11:14 AM   #8
The receptacles are lacking in the garage. Night lights will not be invading my garage. I have every night light ever made throughout the house, mostly bedrooms and the basement. However, after giving it more thought, I am considering putting a few more receptacles in the garage. I would probably use the receptacles with an led night light built in. There presently is no gfi protection in the garage. Is it a good idea for the garage door opener to be dedicated? Regardless if code does not specify. Does code specify if a finished garage with a concrete floors needs gfi protection on all the receptacles? I will be fiddling around with some night lights and clamp lights with led bulbs and see what will work for me.
Old 02-01-2013, 11:54 AM   #9
joed's Avatar
Current NEC code requires that ALL receptacles in a garage be GFCI protected.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 02-01-2013, 03:24 PM   #10
I like power failure lights. Works as a night light with photo eye. Lights up brighter if power fails.
If you need a little more light than the night light is providing, you could snatch one out of the outlet and use it as a flashlight.
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Oso954 is offline   Reply With Quote
Old 02-01-2013, 04:49 PM   #11
Electrical Enthusiast
I use and LED nightlight that is plugged into the duplex receptacle where my garage door opener plugs in. It casts a dim light over the garage pretty much 24/7.
Kyle_in_rure is online now   Reply With Quote
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 04:00 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
