Learning Purposes: 3-way Switching - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 09:21 PM   #16
" Euro " electrician
frenchelectrican's Avatar
On the last drawing Oui, you got it.
That how it supposed to do it in correct way.
Merci,
Marc
Noté: however I have to fix my monitor somehow I did not see the colour marking so therefore the remarked white should be on black supply.
Old 05-31-2011, 09:32 PM   #17
I=E/R
a7ecorsair's Avatar
Just a comment. Isn't the re-identified white wire supposed to be connected to the black supply?
a7ecorsair is offline   Reply With Quote
Old 05-31-2011, 09:38 PM   #18
Oui That is normal pratice we do that all the time.
Merci,
Marc
Old 06-01-2011, 08:08 AM   #19
joed's Avatar
Rewards Points: 12,362
YES. The black and white between the switch and the fixture must be reversed. You are not permitted to have two whites(even remarked) connected to the fixture. Switching them at the fixture is all that is requried. The switches will still be wired correctly.
Old 06-01-2011, 01:49 PM   #20
Rewards Points: 512
Thanks joed. I know that rule about "two white wires (even remarked) on the fixture", but I missed it in the pic.
How 'bout this?
learning purposes: 3-way switching-3waywiring-before-edit2.jpg
Old 06-01-2011, 02:12 PM   #21
joed's Avatar
Looks good now.
The Following User Says Thank You to joed For This Useful Post:
sirsparksalot (06-01-2011)
Old 06-01-2011, 04:28 PM   #22
Rewards Points: 512
Took just 21 posts
Old 06-01-2011, 11:15 PM   #23
Now with your final drawing .,, C'est Bon !!!
Merci,
Marc
fluorescent light on a low voltage switching system? lulufarm Electrical 1 05-13-2011 12:00 PM
Switching from 15 amp range hood to 20 amp dedicated circuit BFDvollie Electrical 2 09-04-2010 08:03 AM
Just learning on how it works.. llckll Electrical 9 01-21-2010 08:29 PM
entrance/hallway light switching j77 Electrical 3 05-21-2009 06:53 AM
Learning the NEC for the NON-Professional WaldenL Electrical 33 01-22-2009 09:22 PM
