Old 04-16-2009, 03:59 PM   #1
Maureen
Default Learning how to read a multimeter
Does anyone know of anywhere on the internet that would give some easy to read instructions on how to use and read a multimeter to test normal household currents and such?
Maureentoo is offline   Reply With Quote
Old 04-16-2009, 04:08 PM   #2
RippySkippy's Avatar
Do you know the brand of your MM?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-16-2009, 04:11 PM   #3
Maureen
I haven't bought it yet, so no.
Old 04-16-2009, 05:39 PM   #4
Power Gen/RS Engineer
MAUREENTOO-
Most of the digital meters on the market are autoranging which means that there is no range adjustment (or rather that it autoranges by default). Do you really want to measure household current or are you looking to measure voltage and possibly continuity (much more common for a homeowner)?
J
Think of how dumb the average person is. Now remember that half of all people are dumber than that-George Carlin
BigJimmy is offline   Reply With Quote
Old 04-16-2009, 05:57 PM   #5
Yoyizit's Avatar
Get one with a "low Z" option so it doesn't respond to phantom voltages.
Old 04-16-2009, 10:03 PM   #6
Tool Geek
PaliBob's Avatar
Maureen, don't feel bad, a lot of others have asked the same question:
http://www.google.com/search?sourcei...+to+read+a+DMM
DMM's come with a set of Red & Black Test leads
The DMM usually has three or four input jacks
To measure AC Voltage, Do not use any jack that's labeled mA or A (for Amps)
Plug one lead into the COM(Common jack)
Plug the other lead into the V Jack (sometimes labeled V Ω
Set the range switch to 200 VAC or Auto
(some meters just have Volts scales with a separate slide switch for AC/DC)
Don't be concerned about reversing the leads. The meter will read the same for voltage.
Read the disclaimer:
http://www.diychatroom.com/f18/announcements/
Disclaimer
& Stay Safe
.....Bob
Old 04-17-2009, 10:52 AM   #7
Well then you're in luck...when you buy your MM it will come with a manual...READ IT!
LMASD
Old 04-17-2009, 10:58 AM   #8
Learning by Doing
Leah Frances's Avatar
Like OP I am also trying to gain some utility from my meter. I'm a girl, so the first thing I did was read my manual - and it tells me how to do X, Y, and Z.
But, it would be helpful to know where to learn some theory so that I understand. Or, in a given troubleshooting situation, what to test. Or, what's normal readings at: switch (on and off), outlet, light fixture, etc.
Eg. I know how to test resistance, just not when or why I'd want to test it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-17-2009, 11:15 AM   #9
Checking resistance (continuity) will test switches and other devices. When checking resistance first make sure there is no power on what you're testing or you'll let the magic smoke out of your meter.
47_47 is offline   Reply With Quote
Old 04-17-2009, 12:46 PM   #10
Yoyizit's Avatar
Originally Posted by Leah Frances View Post
I'm a girl
Current (I, for the French word intensité) make things go.
If things don't go, check that voltage (V) is present. I=V/R.
If no V, then no I.
If V is present in the right amount but not enough I is there, then R (resistance) must be too high. There is no other reason, in a DC circuit.
R is for DC circuits.
Z, impedance, is for AC circuits. Z can get messy to deal with.
Troubleshooting is a science onto itself.
If you get into a situation that seems to violate V = IR it means you are assuming something that is not true. There are many ways this can happen.
I don't meet many girls lately
http://en.wikipedia.org/wiki/Girl
As to women, see the sentence above beginning with "Z can. . .".
More On This Topic
Hello my name is Mark Blocker with Expert Village. In this segment we're going to cover the visual inspection of fuses and how to manually test a fuse. After removing it if you hold the fuse up into a lighting surface you could see there's a filament... Read More »
How to Test Audio Cables
How to Test Audio Cables by Expert Village
Hello! My name is Kip Bradford and I am here on behalf of Expert Village. In this clip, we are going to look at the different ways that we can test cabling just to see if it has been soldered properly and two, if it might have a problem in terms of... Read More »
How to Test an Alternator
How to Test an Alternator by Expert Village
Hi I'm Aaron Gregory on behalf of Expert Village, and we're going to talk about what happens when your car battery dies. As soon as I put the key in the ignition, I'm going to look for some of those other indicators of whether or not the car has battery... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm here with expertvillage.com and we are installing a new doorbell in this house. Now we have already been through the tool list make sure that we had... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. This is our electric meter that would measure voltage and oms and dc voltage. What we want to do now is this is a digital volt meter and we... Read More »
Testing Batteries With a Multimeter Kent10 Electrical 14 02-04-2009 10:30 PM
multimeter question spikesnet Electrical 3 10-20-2008 12:21 PM
How to use a Digital Pocket Multimeter (to test AA & AAA batteries) ? ehoez Electrical 5 09-01-2008 01:02 PM
Need help identifying multimeter ToddB64 Electrical 9 11-10-2007 02:50 AM
moisture testing with a multimeter ronhud Building & Construction 5 02-27-2007 08:39 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
