#1 |
leading a 3- out of a 2-wire cable
this is what i did - it works but was wondering if there are safety issues:
i lead a 3- out of a 2-wire cable in a junction box to supply power to a circuit end consisting of two recess lightes and an outlet. i simply connected both the black and the red wire to the black feeder wire ? is this an okay practice or is it a safety hazard ? thanks, - a |
#2 |
What did you connect the black and red wires to on the other end?....what is the white connected to on both ends?
#3 |
If you have multiple appliances to supply at the end of your run, you should just use 2-wire throughout, and pigtail all the hot terminals on the lights/receptacles to the black wire. No need to have seperate red and black conductors going to these boxes.
#4 |
sounds like you are saying that you have a two wire feeder, and you are using a three wire cable to feed switched lights, and unswitched recepticles.
If I am correct, you did it the right way.
Master Electrician |
#5 |
thanks everyone !
the white is connected to white on the feeding end. on the feeding end, both red and black are connected to the black feeder. that was the basis of my concern. |
#6 |
Licensed Electrical Cont.
What you did is ok as far as safety, but was pointless as far as practicality. Why not just cap off the red and save it as a spare. Now you have another hot wire to worry about.
What is on the branch circuit you tapped off from? This is an important question.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#7 |
the reason i used 14/3 was because the circuit further on consisted of two recess lights and an outlet, which always needed to be hot. each recess light has its own switch.
i do not know what is on the circuit before because the armored cable is actually coming from upstairs but it is very old (no grounding wire and cloth insulated ). i may just cap it off and replace the source (feeder as i used to call it - what should i call it ?) because this old-timer looks too sketchy ...thanks for all your feedback. - a |
#8 | |
leading a 3- out of a 2-wire cableQuote:
What was there before? What did you change? What did add? What are you trying to accomplish? I could not decipher anything about what you are attempting to do from your original post. |
#9 | |
REGARDLESS of all this, you do need to run a circuit or find a newer grounded feed for this. Unless you can confirm that the old wire is AC cable with the thin bonding strip, which I can almost guarantee it is not, you CANNOT use it for a source. This is an ungrounded circuit and we cannot extend ungrounded circuits for new loads.
| Display Modes | |
| Coaxial Cable Question | bahaisamurai | Home Theater | 9 | 08-08-2007 03:54 PM |
| installing a single pole switch | yummy mummy | Electrical | 18 | 04-27-2007 08:06 PM |
| I really need help! | POOK | Electrical | 34 | 04-20-2007 08:01 PM |
| Old house, new light fixture, too many wires | Persephonee | Electrical | 3 | 01-15-2007 09:58 AM |
| Does a 6 x 12ga wire nut exist? | peeks | Electrical | 1 | 10-02-2005 10:58 AM |
