Old 09-01-2012, 08:21 PM   #1
LCD TV on/off problem
I've got a Philips 42" LCD TV. I've been having problems getting it to turn on. Once it is on, it works perfectly. If it gets turned off, then I have to unplug it and plug it several times before it finally turns on. This problem has gotten progressively worse and worse and now it won't turn on at all. Any suggestions?
spclk142 is offline   Reply With Quote
Old 09-01-2012, 08:32 PM   #2
That's been happening to thousands of people on your brand and Visios.
Google something like "Phillips recalls" or just type in your make and model # then the word complants.
There was some class action suites.
They know exactly what's causing the problum, it's a cap. that goes bad.
They want about $400.00 to fix it at the shops.
Most happen within the first two years.
I gave up and bought a new Sony and have had 0 problums and a better picture, plus it cost me less then $400.00.
spclk142 (09-01-2012)
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 05:16 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
