LCD/TV Above Fire Place - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 10:10 PM   #1
How high above the wood burning fireplace do I need to mount the tv?
jfedorek is offline   Reply With Quote
Old 12-05-2010, 12:22 AM   #2
Rewards Points: 150
As far as possible.
These modern flat-screen TVs already have serious heat-management issues, and eat capacitors like candy. I'd recommend doing everything you can to prevent adding to the problem.
emolatur is offline   Reply With Quote
Old 12-05-2010, 05:25 AM   #3
And Still Learning
We have a one year old Panasonic 50". This TV uses over 800 watts of power and has 3 silent cooling fans.
Might want to rethink mounting it over a heat source.
Know It ALL is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 70 12-08-2013 09:49 PM
Fire Pit Installation droopyd75 Landscaping & Lawn Care 1 09-20-2010 08:01 PM
Recessed Smoke Detector / Fire Alarm / Other Names for Things that Beep Around Fire Fox Electrical 12 07-26-2010 02:42 PM
Fire blocking? Can you use liquid nails? Leoskee Building & Construction 8 09-16-2009 11:02 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
