LCD Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 02:47 PM   #1
LCD Problems
I have two post mounted outdoor lights on either side f my driveway. They are relatively new- one around 2 months, the other just over a year. The oder one works fine. The newer is a replacement for one which had problems after about a yearand now tthe newer one is showing the same symptoms. They are LED fixtures. What happens is the problem one(s) appear to need a long time to come to full brightness and sometimes never seems to ever get there. Incandescent fixtures at the site had no problems. Does anyone have any insight to this??
pfrat@comcast.n is offline   Reply With Quote
Old 01-18-2013, 02:52 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
What is a LCD fixture? Do you mean CFL or LED. CFLs take time to warm up and come to full bright especially in cold weather.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-18-2013, 02:55 PM   #3
Sorry- I meant LED!
Old 01-18-2013, 05:11 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,106
If it is a CFL light ?
Then it is normal !
If it is a LED light
then it has power supply issues,
probably a dryed up filter capacitor.
dmxtothemax is offline   Reply With Quote
Old 01-18-2013, 08:15 PM   #5
A "Handy Husband"
rjniles's Avatar
Are your LEDs line voltage or low voltage?
Old 01-19-2013, 11:29 AM   #6
Line voltage, I guess. Definitely not low voltage.
Old 01-19-2013, 04:18 PM   #7
A "Handy Husband"
rjniles's Avatar
Measure the voltage at the light with the light on. If it remains steady at approx. 120 volts, the problem is the light.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 09:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 09:10 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
