Old 12-12-2008, 05:43 PM   #1
LCD keeps tripping the breaker
So I recently purchased a Samsung 46" LCD TV. I brought it home, plugged it in and it tripped the breaker. (15 amp breaker)
We determined that the TV only trips the breaker when the coax cable is attached to the TV. At one point, the Coax cable gave a spark when we tried to connect to the TV while it was plugged in. I was told there was a short in the TV. Exchanged the TV, same problem...
I had the cable company come in and checked the lines and everything is fine.
The way my living room is wired, my outlets work off two wall switches. The top is always hot, the bottom works off the switch. We figured out today that breaker only trips when the one light switch is turned on. When it is off, the TV works fine.....
I'm on my last leg here before I just return the TV and be done with it. Any suggestions would be appreciated.
gencoed is offline   Reply With Quote
Old 12-12-2008, 06:25 PM   #2
Electrical Contractor
Will reverse polarity trip breaker??
Check here for some info.
You have other problems than the tv.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-12-2008, 08:23 PM   #3
Deja Vu!
I was hoping you would point the guy to this thread.
KE2KB is offline   Reply With Quote
Old 12-12-2008, 08:26 PM   #4
Returning won't solve it. I suggest reading the thread posted...but it is more than likely a hot to ground problem.
I hate it when stupid people wire houses
rgsgww is offline   Reply With Quote
Old 12-12-2008, 08:35 PM   #5
If stupid people wire their own houses, eventually there will be fewer stupid people on Earth<g>
Old 12-12-2008, 08:39 PM   #6
My License Ain't 4 Sale..
Problem is, they may accidentally take other people with them when they leave...
Old 12-13-2008, 04:36 AM   #7
DIYer
Well on the plus side, all this grounded coax is letting people find these miswired outlets. :P
Gigs is offline   Reply With Quote
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
Breaker Keeps Tripping? FinsUp Electrical 4 11-14-2008 10:58 AM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 05:13 PM
