LB Used As A Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 06:23 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
LB used as a junction box
Just installed an "electric eye" control for my landscape lighting. Ran PVC conduit up the outside wall, installed a LB fitting, a female adapter. Screwed the electric eye into the female adapter and use the LB as a junction box. Is this a code legitimate method?
Coastal South Carolina
Old 03-04-2011, 06:28 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
no- however if it is listed with a cubit inches and you don't exceed that listing then there is an exception in the code that you can use to do just that.
A jbox would have been better JMO
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
rjniles (03-05-2011)
Old 03-05-2011, 03:09 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Most case no unless it is stamped cubic inches inside the LB fitting otherwise use the bellbox { WP box } that is the other option it meet the codes.
IIRC most of the half inch LB are not useally stamped Cubic inches at all they start stamp the size when you get 3/4 inch or larger so one trick is use one size larger LB or CC fittign with reducing bushing that I have done few time.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 03-05-2011, 12:35 PM   #4
A "Handy Husband"
rjniles's Avatar
It was 3/4 " conduit and LB that I used as that is what I had. Did not notice if the cu. in. was listed but I will check.
Junction box and light switches travesty Electrical 3 01-18-2011 01:49 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
