LB Fitting Underground??????? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 05:11 PM   #1
LB Fitting underground???????
I'm in Ontario. I have to run wire from the hydro meter outside the garage under concrete floor into the service panel in the mechanical room. In order to get the line low enouch to be under the concrete as required by code the LB fitting outside ends up below grade. What can I do? Is there a different fitting that can be below grade or can I cover the LB fitting in concrete before it enters the house?
Please help asap.
lehmjoe is offline   Reply With Quote
Old 11-25-2013, 05:14 PM   #2
Licensed electrician
Rewards Points: 1,486
I am sure the CEC would require the LB cover to be accessible after installation the same as the NEC. Can you use a 90 degree elbow?
stickboy1375 (11-25-2013)
Old 11-25-2013, 06:37 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why would you want to encase a fitting that is made to be accessible? No way is it listed for that use.
Old 11-25-2013, 07:09 PM   #4
joed's Avatar
Rewards Points: 12,416
You can't use an LB underground. Use long sweep elbow to allow the cables to be pulled.
The Following User Says Thank You to joed For This Useful Post:
Philly Master (11-26-2013)
Old 11-26-2013, 07:55 AM   #5
I would like to but the 90 degree elbow brings it too far out from the wall so how do I get the vertical pipe against the wall to meet the hydro meter.
Old 11-26-2013, 08:04 AM   #6
please provide a picture
itsnotrequired is offline   Reply With Quote
Old 11-26-2013, 08:06 AM   #7
I don't want to encase it I'm trying to get the line from coming out of the foundation wall below grade up to the hydro meter.
Old 11-26-2013, 08:12 AM   #8
Right now it's just a 4 ought (sp?) 3 wire coming out of a 2" PVC pipe coming out of the foundation wall. There is no basement, it's a slab on grade construction so all plumbing and the service cable is underground.
Old 11-26-2013, 08:13 AM   #9
and right now it's covered in snow!
Old 11-26-2013, 08:46 AM   #10
can you make a sketch? you say it is slab on grade but then mention a foundation. is the 2" conduit coming out of the footing? or better yet, does that 2" conduit come out above or below grade?
Old 11-26-2013, 01:28 PM   #11
joed's Avatar
You can't bury an LB. You have two choices, raise the point of entry above grade or dig a hole and leave the LB exposed as if it was a basement window below grade.
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Underground Run To Outlet For Pool. LB fitting out of siding? collegetry Electrical 35 06-26-2012 10:16 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
