Laundry Room Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 08:54 PM   #1
laundry room wiring
i am wiring my new kitchen extention, in the laundry room i have the dryer sorted out but a bit hazy on the washer and receptical , the regular rec is on the main rec ciruit (15 amp) and i have a dedicated line to the washer rec but i ran 14/2 to it im thinking it should be 12/2 and does the other rec need to be on that same line seeing as it is in the laundry room. i am in ontario canada, thank you for taking the time to read this
brit in canada is offline   Reply With Quote
Old 01-07-2011, 09:15 PM   #2
Electrician
Rewards Points: 792
As long as you put a 15A plug and 15A breaker you will be fine.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
brit in canada (01-07-2011)
Old 01-07-2011, 09:29 PM   #3
so the whole 20 amp circuit thing i am reading about online is for the US only?
Old 01-07-2011, 09:45 PM   #4
Electrical Contractor
kbsparky's Avatar
As far as I know, that is the case. In the US, we are required to install 20 Amp dedicated circuits for the laundry, as well as for the small appliances in the kitchen.
-KB
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Laundry room in basement - Where do I start? techprincesse Remodeling 2 10-21-2009 10:07 PM
Laundry room in the basement Trish99 Remodeling 3 10-18-2009 11:26 PM
Laundry room handifoot Electrical 12 03-25-2009 11:06 AM
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 07:08 PM
