Laundry Room Light switch Problem
I need some help. I was helping a friend who had a faulty light switch in their laundry room. The light switch was getting old and when you would switch it on it began to fall and the light would go out. I replaced the switch with a new one. The problem is this: The first time you turn the switch on the light comes on, if you turn it off and then on again the light flashes on-off-on-off-on and stays on. If you turn it off the next time the light comes on the first time and stays on, if you turn it off the light goes on-off-on-off-on and stays on again. This pattern always happens. I tried another new switch and it has the same flashing problem. Do you have any idea why it does this? What can I do to make it turn on and of without it flashing every other time? Your help is much appreciated. Thanks
