#1 |
Laundry room
Hey folks,
Can someone tell me if I can share general purposes receptacles in a laundry room with an adjacent room? Also, does a washing machine need its own dedicated 20 amp circuit? Thanks
I'm gonna hurl myself against the wall because I'd rather feel bad than not feel anything at all Warren Zevon |
#2 |
as seen on tv
Laundry room
min 1 20 circuit to laundry receptacles within 6 ft of appliance no other outlets on the run. I believe you can run separate convience receptacles between rooms .
#3 |
Laundry room
Your washing machine needs its own circuit yes and you need another dedicated receptical in the laundry room also. So two circuits
#4 | |
Licensed Pro
Laundry roomQuote:
The NEC requires a dedicated laundry circuit. It makes no mention of a dedicated circuit for a washer.
"Life is hard. Life is harder when you're stupid." John Wayne |
#5 |
Laundry room
How about laundry room lighting?
#6 |
Laundry room
I believe you are only required to have at a minimum 1 20 amp dedicated circuit intended for the washer/gas dryer (at least that's how it works at my house). Obviously with an electric dryer it needs its own dedicated circuit separate from the washer. Anything beyond that is up to you, so if your lights are on a different circuit than the required dedicated circuit than I wouldn't see a problem tie-ing into the lights. Just make sure they are not tied into the one required circuit for the laundry room and you should be fine.
#7 |
Laundry room
I have two 20 amps in laundry, but its pretty much a waste. Only things that are plugged in one of the 20 amp circuits pull 45 watts.
#8 |
Laundry room
I am a newbie here. Interesting discussion has been going on, I get to know new thing here and I hope this forum would help me in getting more info regarding electrical.
#9 |
Laundry room |
#10 |
Laundry room
One of the circuits can be extended to other parts of the house or basement so long as the other serves just the laundry receptacle.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#11 | |
Laundry roomQuote:
Yeah, I could extend that and use it as a dedicated 20 for a bathroom right next to it. Its on a slab so no basement runs...there is steel rafters in this area, so mounting a box in the attic may not be easy. Not to mention 2 ft of blown in insulation.
#12 |
Licensed electrician
Laundry room
The bathroom circuit can either serve multiple bathroom receptacles only OR 1 bathrooms receptacle and additional loads like exhaust fans and lighting if less than 10 amps. It cannot serve other areas of the house.
#13 | |
Laundry roomQuote:
I know, I meant to pull it out or cut it in the attic, install a junction, and run new 12/2 to the bathroom. I'm not saying I actually plan to do this however. |
| Display Modes | |
| Laundry Room Dimension Question | jonathan03 | Appliances | 1 | 01-17-2009 11:08 AM |
| Laundry Room and half bath overhaul! | gone_fishing | Project Showcase | 10 | 04-29-2008 08:08 PM |
| occasional sewer gas smell in laundry room | nebben | Plumbing | 3 | 03-25-2007 11:35 AM |
| Replacing a laundry room roof. | Tomcat1066 | Building & Construction | 5 | 11-11-2006 04:08 PM |
