-   -   Laundry room (http://www.diychatroom.com/f18/laundry-room-40971/)
handifoot 03-23-2009 10:02 PM
Laundry room
Hey folks,
Can someone tell me if I can share general purposes receptacles in a laundry room with an adjacent room?
Also, does a washing machine need its own dedicated 20 amp circuit?
qbert 03-23-2009 10:41 PM
min 1 20 circuit to laundry receptacles within 6 ft of appliance no other outlets on the run. I believe you can run separate convience receptacles between rooms .
dSilanskas 03-24-2009 04:40 AM
Your washing machine needs its own circuit yes and you need another dedicated receptical in the laundry room also. So two circuits
HouseHelper 03-24-2009 05:46 AM
Incorrect.
The NEC requires a dedicated laundry circuit. It makes no mention of a dedicated circuit for a washer.
handifoot 03-24-2009 07:17 AM
How about laundry room lighting?
theatretch85 03-24-2009 07:24 AM
I believe you are only required to have at a minimum 1 20 amp dedicated circuit intended for the washer/gas dryer (at least that's how it works at my house). Obviously with an electric dryer it needs its own dedicated circuit separate from the washer. Anything beyond that is up to you, so if your lights are on a different circuit than the required dedicated circuit than I wouldn't see a problem tie-ing into the lights. Just make sure they are not tied into the one required circuit for the laundry room and you should be fine.
rgsgww 03-24-2009 07:28 AM
I have two 20 amps in laundry, but its pretty much a waste. Only things that are plugged in one of the 20 amp circuits pull 45 watts.
Paxton 03-25-2009 05:46 AM
I am a newbie here. Interesting discussion has been going on, I get to know new thing here and I hope this forum would help me in getting more info regarding electrical.
rgsgww 03-25-2009 07:03 AM
Welcome to the forum! I will be glad to help you on some electrical questions.:)
AllanJ 03-25-2009 07:47 AM
One of the circuits can be extended to other parts of the house or basement so long as the other serves just the laundry receptacle.
rgsgww 03-25-2009 08:07 AM
Yeah, I could extend that and use it as a dedicated 20 for a bathroom right next to it. Its on a slab so no basement runs...there is steel rafters in this area, so mounting a box in the attic may not be easy. Not to mention 2 ft of blown in insulation.:laughing:
Jim Port 03-25-2009 09:33 AM
The bathroom circuit can either serve multiple bathroom receptacles only OR 1 bathrooms receptacle and additional loads like exhaust fans and lighting if less than 10 amps. It cannot serve other areas of the house.
rgsgww 03-25-2009 11:06 AM
I know, I meant to pull it out or cut it in the attic, install a junction, and run new 12/2 to the bathroom.
I'm not saying I actually plan to do this however.
