Lathe Machine From China...HELP! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 05:08 PM   #16
Originally Posted by J. V. View Post
VFD's will accept a single phase input and output three phase. At 3Hp, no derating required. Now, you can rock and roll. Much cheaper than a phase converter and no moving parts.
But won't he need a VFD for each motor? assuming he has rapids and coolant.and what about clutches and lighting?
lemuzz is offline   Reply With Quote
Old 04-19-2009, 11:17 AM   #17
Rewards Points: 246
Yes. Lathes that I am familiar with use a main motor for driving the lathe itself. If other motors are on this machine then he must change or rewire them to suit the voltage and hertz. Unless this is an automated lathe, there should be no cooling fluids. One motor and several pulleys to adjust speed.
Good question.
Old 04-19-2009, 01:06 PM   #18
its quite a straight forwad machine just the motor i'm having an issue with
but i'd still need a transformer to up the power to 380v from the vfd as power in and power out of a vfd have to be the same?
-- power into vfd (single phase) to
-- output to 3 phase 50hz to
-- step up transformers to
-- the 3 ph. motor 380v 50hz
something like this:
http://www.variablefrequencydrives.n...90010TDN4Z.htm
i think im almost there.
thanks
jackoneill is offline   Reply With Quote
Old 04-19-2009, 02:37 PM   #19
Idiot Emeritus
Rewards Points: 1,492
A transformer will be needed to use a VFD with a 380 volt motor powered from a single phase 240 volt source. It'll need to be 3 KVA minimum, if the motor is expected to produce its rated HP continuously (not likely on a lathe), then a 5 KVA will be best. It'll need to be 240 volts on one side, 480 on the other. The 480 side might be listed as the primary, and the 240 as the secondary. A transformer like this doesn't care which way the power flows. Usually, they're used as step-down, but they work just fine as step-up. It'll be much less expensive to step up the 240 single phase and use a 480 volt VFD than to use a 240 volt VFD and step up the 3 phase to the motor.
Most VFDs can be programmed for a 50 or 60 HZ motor. The actual voltage supplied to the motor will depend entirely on speed and load. For example, if the motor is running at 50 HZ, and turning just the spindle, the drive will supply a voltage of about 150 or so. When a load is applied, the voltage will increase to whatever is needed to maintain the pre-set speed.
The VFD will supply power to the motor only, nothing else. What type of control is it? If it's a simple manual switch, the VFD and transformer will work fine. If it's a start-stop button and a magnetic starter, this will get a bit more complex. If there are other 380 volt devices involved, it'll get even more complex. The reason I ask is because a 480 volt transformer will be easier to get than a 380 volt one.
Rob
P.S. If the lathe needs to reverse, it's pretty easy to do with most VFDs.
micromind is offline   Reply With Quote
Old 04-19-2009, 03:49 PM   #20
Rewards Points: 246
thanks
You need 460 volts input to the VFD to get 380 volts out of it. Since you have 240 volts you need a transformer as Rob has told you. Now, you have a choice, since we are now only dealing with the motor, right????
Replace the motor or install a drive and transformer.
I am going to give you a price comparison on both so you can see what you need to do. I will use Weg Electric for the demonstration. They excel in metric motors as well as Lafert USA. They have true metric frames. If you do not get a true metric frame it may not fit in the space you have. The web site you have in your post is not the official Weg Electric website. They are online distributors only. To look at the official Weg Electric web site you must go to www.wegelectric.com.
1) Weg Electric True Metric Frame Motor:
Cat Number: 00209EP3E132S
3 HP / 2.2 Kw.
RPM: 900 @ 60 Hz / 750 @ 50 Hz.
IEC Frame: 132S (Check your nameplate) Must be the same.
Voltage: 230/460 @ 60 Hz - 380/415 @ 50 Hz.
$520.00
Find this motor and print out the frame dimensions.
2) Weg Electric VFD 08 Series:
Cat Number: CFW080065TGN1A1Z
460 Volt
3 HP.
6.5 Amps.
$460.00 Does not include transformer price. This could be the deal breaker.
IMO, the motor replacement will be the cheapest way due to the transformer. But you must be sure the motor will fit in the space you have. Go to the web site and print a cad diagram of the frame dimensions. All measurements must be the same. The bolt hole pattern and shaft size will be the same if your motor is on a 132S frame. But height and total length may vary, so be sure.
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 06:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
